Preparing an M for painting
marlinm51
05-13-2005 04:43:23
I've been getting my Farmall M ready for painting. I'm using a large twisted-wire cup on a 9" angle grinder and a 3" one on a 4" angle grinder to remove/scuff the paint. Some of the paint on the outer sheet metal surfaces comes off really hard or not at all, other surfaces (such as under the fuel tank) come off really easy. Do you think this tractor has been repainted only on the outer surfaces? Can I assume that any paint that is resistant to these 2 grinders is ok to paint over? Is the next step to sand the remaining paint to a feather edge? Thanks for your help
Frank Stalfire
05-13-2005 19:36:15
 Re: Preparing an M for painting in reply to marlinm51, 05-13-2005 04:43:23
HI
It does not mean the tractor has been repainted, the OEM's can and somtimes do use different paint in different areas, check the sensitivity to solvent by wetting a rag with thinner and rub existing paint, if it rubs off or is not tightly adhearent to the surface you should remove it.
Frank
