Surface preparation
Marv
05-18-2005 16:43:09
I,m just getting started on a restoration project. I have a Super M that was restored several years ago and I want to give it a new paint job. I'm considering one of the high dollar paints such as Dupont. My intent is to give the tin a very good sanding. However, I,ve been told that it is necessary to sandblast all of the old paint off the tin if I,m going to use one of the new paints. Please give me some advice. Thanks, Marv
CNKS
05-19-2005 06:38:20
 Re: Surface preparation in reply to Marv, 05-18-2005 16:43:09
If the paint is in good condition you can sand it and seal it with an epoxy primer. Use the same brand of paint for epoxy, surfacer, and topcoat and you will be ok. Problem is you don't know what's under the old paint. You say it was restored, meaning that it was taken to bare metal and painted properly, or, perhaps the guy painted over rust, meaning you really should sand it down to bare metal again. Be careful if you sandblast the tin. Some of the commercial high pressure rigs can warp it. If you have a small DIY sandblaster, I don't think warping is a problem. Just be careful. I prefer to chemically strip and then sand off any remaining rust.
