first timer painting
ken powell
05-24-2005 15:31:08
Help! I have never ever painted anything in my life so bear with me I have a 44 2n with good sheet metal but it does have some rust i have access to an electric "lemmer" paint gun or should i use a rattle can or brushes or??? do i need to sand blast? what is "wet" sanding just as it sounds? what about hardener? do i need it? clear coat? please excuse my ignorance just trying to learn here
thanks in advance
Ed in Maine
05-24-2005 19:20:36
 Re: first timer painting in reply to ken powell, 05-24-2005 15:31:08
I would start with a few searches here on the forum, there is a lot of info.
Me personally, I hate airless/electric sprayers, never can get them to flow just right. I just use a conventional sprayer (bottom feed). There is nothing wrong with rattle cans, easy to use and you can go at your own pace. Wet sanding is for when you are getting down to business, it keeps the sand paper from clogging when using fine paper and flows good when trying to feather out paint layers. If you use enamel paint, you don't need a clear coat. Clear coat is pretty expensive by the way, can cost more than the paint for the good stuff!
Post specific questions you have and people on here will help you through it. I have experience painting cars, this is my first tractor so I am right here with you. How much sanding is necessary, does it need sand blasting...?? it all depends!
Ed
dennis in or
06-09-2005 22:02:27
 Re: first timer painting in reply to Ed in Maine, 05-24-2005 19:20:36
anyone ever painted a whole tractor with rattle cans? i am useing rattle primer but had not thought of spraying the tractor by cans, tips??
Ed in Maine
06-13-2005 13:49:37
 Re: first timer painting in reply to dennis in or, 06-09-2005 22:02:27
My nieghbor did it on his Ford 3000. It looks good, everything is blue! The only difference is you don't get that glossy look out of a rattle can, but you could probably go over it with clear to get the gloss?
Ed
