Repairing paint chip
PaulW_NJ
06-07-2005 15:16:20
I finished my 51 Farmall Cub last fall, using MP 170 primer, and MTK topcoat. The other day, a piece of steel plate fell against it, and nicked the corner of front axle, chipping the paint down to the metal (approx the size of half a dime). Of course it"s right in front - the most prominent place possible! Not that I"m entering contests or anything, but after all the restoration work it"s the first thing I see. What"s the best way to paint it while avoiding overspray to the rest of the tractor? I have a HVLP gun, but not a spot gun.
It seems when I"ve tried to go back and repaint specific parts of a tractor, I get dulling on the other areas of the tractor, even though I"ve thrown a tarp loosely over the rest. I thought of covering the entire tractor more tightly with a tarp, and cutting a small hole right at the chipped spot. Is that the way to do this?
I assume I should feather the edges of the chipped area, but do I prime the spot first, or just topcoat?
Suggestions by those who have done this would be very welcome and appreciated.
Paul
Rod (NH)
06-07-2005 16:34:44
 Re: Repairing paint chip in reply to PaulW_NJ, 06-07-2005 15:16:20
Paul,
The easiest, quickest way would be to use an artists brush and touch up the area with both the epoxy and the color. It would still show but would not be as noticeable as it is now. In order for the repair to not show at all, significantly more work is involved. With this approach the area damaged has to be featheredged and some additional area masked off. By masked, I mean masking tape and paper so that no overspray can possibly get to any place where it is not wanted - at least in the general area of the work. A tarp should be OK for the more remote areas of the tractor. I am not familiar with your particular axle so I can't advise how to mask it. On my AC-B, I'd probably wind up repainting the entire axle for the repair to not show at all. In any event, the repair area needs to extend to some point(s) on the axle that provide a convenient visual break, such as a sharp edge or a joint, that naturally provides a line of demarcation between the old and new. It goes without saying that all paint in the repair area needs to be scuffed also. It sounds to me like such a situation would be ideal for the use of a Preval sprayer - they're cheap enough - rather than firing up a full-sized gun for a relatively small area.
Rod
PaulW_NJ
06-07-2005 19:52:28
 Re: Repairing paint chip in reply to Rod (NH), 06-07-2005 16:34:44
Rod
Thanks for your reply and suggestions. I"ll try the artist brush technique. One thing though, I"ve tried an art brush in the past for bolt heads, and found that I couldn"t get very good coverage - you could almost see right through it, whereas spraying would cover fully in one coat. Is that normal - do you have to go over with many successive coats when you brush urethane on? Using MTK, would it help to leave out the reducer when brushing?
Paul
Rod (NH)
06-08-2005 08:36:48
 Re: Repairing paint chip in reply to PaulW_NJ, 06-07-2005 19:52:28
Yes, it's normal. You should plan on three applications by brush. I haven't had to do more than three on bolt head touchups. Yes, leave out the reducer for brush application. The MTK is runny enough as it is and since it is not finely atomized when brushed on, it will have a greater tendency to run and sag. However, three light applications should do it. I'd feather-edge the area, ending with 400 grit. That will at least double the area you need to cover but will eliminate the sharp edge and be much less noticeable. I'd brush on a little epoxy (one coat) on any bare area first and do a light sand with 400 prior to the color (just to smooth any epoxy edge). I'd also try to extend the second and third application of color a little beyond the previous one. The last coat or two will have to extend some onto an unsanded area of the original but that shouldn't be a problem. You'll be left with a slight visable line at the overlap where the new stops and the old begins but it shouldn't be severe. You'll know it's there but it probably will not be noticed by others unless they stare closely at the exact location.
Below is a chip in MTK that I got at the edge of the hand crank opening on my AC-B. I didn't featheredge anything - just did a brush touchup. The chip didn't go all the way to bare metal but was between the epoxy and the first coat of color. The main chip edge is deep because I used 3 coats of color plus 3 coats of clear originally. Only color on the touchup. The chip is about 1/4" long and was caused by hard pressure of the hand crank against the edge of the opening during cranking. It is very noticeable in this extreme closeup but is not bad when you get about three feet back, such as when you are normally standing and looking down at it. It becomes hard to see unless you are looking closely or know it's there :o).
third party image
PaulW_NJ
06-08-2005 20:00:40
 Re: Repairing paint chip in reply to Rod (NH), 06-08-2005 08:36:48
Thanks Rod, for the tips. I"ve cut and pasted them into my "notebook" of refinishing posts from this site. I"ll give the brush technique a try.
Paul
