Filler shows thru paint
Dave BN
06-13-2005 18:11:57
Seems like I can see my filler (bondo) thru my paint as a dark spot. Maybe it's just because I know where it is, but I don't think so. Any tricks to hide this better? More primer coats or more finish coats? Dave.
Rod (NH)
06-13-2005 19:38:49
 Re: Filler shows thru paint in reply to Dave BN, 06-13-2005 18:11:57
Hi Dave,
I think the best way to avoid that is to provide a consistent shade of base prior to adding any color topcoat. IMO, you should not try to apply color directly to an inconsistent base. If I have both filler and old paint or filler and primer (or surfacer) showing, I will always cover everything with a single coat of either a non-sanding primer or a sealer. This would provide a consistent base for the color application and would usually be a shade of gray. The color topcoat should typically be at least two coats and probably three. Trying to cover up a multicolored base with more color coats is simply wastefull of money and materials.
third party image Rod
