I have a 1945 2N in excellent mechanically condition but it is pretty bad cosmetically.This tractor is a worker and will continue to be. The reason I decided to paint it is because I had to tear it down to replace the throw out and pilot bearings. Now I would like to paint it but I don"t have much time since I need it to rake our riding ring. I figure since its a work tractor it doesn"t make sense to spend hours painting it. What would you recommend as far a bare minimum tear down. I already have the hood, air cleaner,battery box and all of the guages removed. Also the whole thing has a light rust cover except the engine. I was thinking of using Rust-oleum rusty metal primer followed by a Rust-oleum top coat that closely matches the Ford Gray. (If one exists). There are a few dents and dings that I will try and hammer out and braze as best I can. Any tips or hints? Again this is a work tractor that I will probably own and work for a long long time. And I don"t have much time to do it in. Also I should that sand blasting unfortunately won"t be an option since I don"t know anyone that has one. Thanks in advance for all of your help. Jeff Bath
