Super Dexta hydraulic lift
Bill in GA
06-17-2005 08:51:32
The lift on my 1964 Super Dexta quit working. I replaced the o ring on the piston in the ram cylinder which was worn out.I also replaced the control valve seat and cleaned the valve. Now the lift go up with the lever in the down position . When I remove the valve it will go down.With the valve out it goes up as soon as the tractor starts. The only way to get the lift to go down is to remove the plug and let the fluid out. Is there something else to check ?
