any tricks to painting the wheels
scdietsche
06-20-2005 14:41:34
i was wondering if there are any tricks to painting the wheels. if you got to take the rubber off or is there a way to leave the rubber on and paint the wheels of a tractor without getting the rubber all full of paint. i got an oliver tractor that i'm painting right now both the front and back wheels
thanks scott
rustyj14
07-10-2005 12:07:33
 Re: any tricks to painting the wheels in reply to scdietsche, 06-20-2005 14:41:34
i carefully clean the tire next to the rim, with laquer thinner. If there are any of those little rubber fingers sticking up, i cut them off close with a razor blade! then i carefully mask around the rim, in close, with masking tape (3M), about 3 strips around. then laying full sheets of newspaper on the tire, i cut around the rim with a razor blade. Then i tape the edges of the newspaper, until the whole tire is covered! Makes a nice job! any small amount of overspray can be removed with laquer thinner later on. just don't wipe the new paint on the rim with laquer thinner! It will ruin yer paint! by: Rustyj
HOOKER
06-25-2005 19:08:04
third party image
SAND BATH
Jim Evans
06-25-2005 07:06:34
I have done all methods. It is best and sometimes faster to take the tires off and do it right. Sometimes the tires are so old that they won't survive the removal. Then you use a lot of masking tape. If you can at least break the tire from the beads to leave more room to paint the edge of the rim, it will make things a lot easier. Just spend a lot of time masking - the results will be worth it in the end.
Jim
HOOKER
06-25-2005 05:24:16
third party image
GETTA BIG ROLL OF TAPE
HOOKER
06-25-2005 05:22:06
third party image
Van in AR
06-24-2005 21:16:54
If im not going to take the tires off I get some masking tape and tape off close to the rim as possible then use a soft cloth and wipe some brake fluid on the rest of the rubber (do not get it on the wheel), after the paint is dry you can take some thinner and just wipe off what little over spray is left along with the brake fluid. Works fine. Tires look good and black.
Van
Tim...Ok
06-22-2005 12:10:28
It"s best to take off the tires and clean and paint the inside,but if you plan on leaving them on,use vaseline or wheel bearing grease to "mask" the tire,when paint is dry wipe it off..simple.eh?? sure works better than trying to tape and paper mask it.
HOOKER
06-26-2005 05:59:31
 Re: any tricks to painting the wheels in reply to Tim...Ok, 06-22-2005 12:10:28
what did ya ever do about those pecans that went south
jake
Tim...Ok
06-22-2005 12:10:26
Tim...Ok
06-22-2005 12:09:11
TwinCreek
06-22-2005 04:04:27
I found that cutting about a 4-6" wide piece of sheet metal and wrapping it around the rim right at the joint of the tire and rim does a good job of keeping paint off the tire. Length is variable depending on how big the rim is. I then drape a drop cloth over the rest of the tire to keep the overspray off. I used this method on both car and tractor tires and never got any paint on the tires.
CNKS
06-20-2005 16:40:20
Take off the tires, you need to clean and repaint the inside of the rims anyway.
TDK
06-20-2005 19:34:25
 Re: any tricks to painting the wheels in reply to CNKS, 06-20-2005 16:40:20
I would also recommend removing tires. But if you choose not to, they can be masked off. It is a little time consuming though.
Dixieland
06-20-2005 15:32:47
I am probably gonna git scolded for this but if you want to do a good job either let a pro do it or remove the tires. You can try masking but don"t know if you could get a good job.
