Farmall H Paint
C Cairns
06-28-2005 05:48:58
Who sells the correct paint for the Farmall H? What colors were used?
RustyFarmall
06-30-2005 17:25:16
 Re: Farmall H Paint in reply to C Cairns, 06-28-2005 05:48:58
Your best bet is your local Case-IH dealer. A very high quality paint that covers well and results in a very high gloss. Does not require any high tech equipment and does not require any special breathing apparatus, just a good respirator with the proper filters.
CNKS
06-28-2005 19:26:06
IH 50/Dupont 7410/PPG 70019 until sometime in 1949. IH 50 is no longer available from Case-IH, so it has to be mixed. IH 50 was replaced by 1102B, then 201. I do not know if these two colors can be mixed. 201 was replaced by IH 2150 in 1961 -- This is the paint that IH considered "correct" for repaints of post 1949 tractors. It is sold by Case-IH dealers. 2150 crosses to PPG 71310/Dupont 96766.
Dixieland
06-28-2005 15:56:25
It depends on what you consider correct. I bought the primer and paint at the Case IH dealer. Good paint and durable if applied correctly.
Charles Park
06-28-2005 06:38:37
PPG sells the paint and several others do as well. You might want to research the archives to get some more information. There is plenty to read.
