Whats wrong with my spray gun?
Andy in Ohio
06-28-2005 19:36:14
I cleaned all the dried paint from my Powermate spray gun, inside. Now it sprays in spurts and starts to run out of air. It acts like it is not drawing paint contiously. Any ideas what I did wrong? Thanks, Andy
rustyj14
08-28-2005 20:15:45
 Re: Whats wrong with my spray gun? in reply to Andy in Ohio, 06-28-2005 19:36:14
Pick up the gun in yer right hand, at eye level, with the nozzle pointing to yer left. Where you can see the shiny rod (needle) going into the spray head, put one drop of motor oil in that area, then work the trigger about 15 times, wipe off any excess, and try it. Sometimes that packing dries out, and causes spitting.
Joe(TX)
07-20-2005 06:12:17
Its either the vent pluged or more likely the needle packing leaking.
JerryB
07-04-2005 10:17:08
Dismantle the gun and soak it in high strength laquer thinner. Not the cheap stuff but the more expensive and much "hotter" good stuf.
Brush and flush it out after soaking for a couple of days and then reassemble and try it again.
JimV
06-29-2005 02:10:14
Andy, check your vent to the gun. If it is plugged, will not allow air into the canister and gun won't draw paint out.
