MUST FOR RUST
dennis in or
07-02-2005 20:53:56
i can still see a little paint on my frame . will the (MFR) stick ? #2? do i need to get to bare metal or can i light sand and prime over some of the old paint on the frame axles ect?
CNKS
07-03-2005 10:39:02
 Re: MUST FOR RUST in reply to dennis in or, 07-02-2005 20:53:56
You don't have to get 100% of the paint off, maybe 99%. That is enough to be visible. After I have oven cleaned, angle grinded, and needle scaled etc, if there is a little paint in the nooks and crannies, I figure it's stuck pretty good and won't hurt anything. Epoxy primer will seal it in. On the other hand, if you mean a significant amount of paint on the flat surfaces, you haven't tried hard enough to get it off. Rust preventatives/converters are not intended to be used over paint.
HOOKER
07-03-2005 10:05:46
getya some 3M scotch brite pads that'll fit on yer die grinder, the course will take it off and not tear up the frame
jake
