First paint job , need advise
Tim
03-01-2002 04:49:47
This will be my first try and I need some help, I am not looking for a million dollar job just want it to look nice and clean you know. My first question what is the easist way to remove all the grease and oil, second there is some rust and pitting I dont have the time to sandblast etc. is there a chemical treatment I can use ? I know I have skipped alot of detail ( Ill ask those questions later,) What is the best kind of primer to fill in the pitted areas etc. and what is the best, hardest paint a novice can use without messing it up. ? Thanks for the help Tim
Painting Part II Thoughts - Rod (NH)
03-10-2002 16:20:31
 Re: First paint job , need advise in reply to Tim, 03-01-2002 04:49:47
Painting Part II – My Thoughts
Tim,
Continuing on from Part I, I will try to express my thoughts on surface preparation and other stuff prior to applying any topcoat paint. I will also try to address the broad (not specific) issue of cost because most of us have to deal with compromises and cannot always afford “the very best”.
I will repeat a worn phrase: surface preparation is 95% of the job. That’s true (probably more like 98%) and it’s where most of the hard work takes place and it takes the most time. IMHO, it is more important than selecting the type of paint for the topcoat. A relatively inexpensive brush alkyd job done over a carefully prepared surface can outlast and be “better” than the most expensive polyurethane topcoat applied over a poorly prepared surface. However, as with selecting the topcoat type, decisions have to be made concerning the goals of the owner, the budget for the job and, assuming a complete DIY project, the facilities and equipment available for use.
I guess the first thing that pops up is sandblasting and dealing with rust. My personal experience is with automotive painting. However, a hood is a hood and rust is rust whether it is on a car or a tractor or whatever. The absolute best surface preparation is to sandblast to bright metal and start all over. This would be the route you would take if your goal was “the very best”, you were going to use a very expensive topcoat and cost was a minor consideration…if you did not have sandblast equipment, you would hire it done, including transporting the tractor and parts to and from wherever for this work. I believe that this approach is not always necessary...nor is it realistic in many cases. There are some lower cost alternatives that can do a very nice job, indeed.
I have sandblast equipment. My current setup is a pressure blaster fed by a 17 scfm air compressor…arguably the high end for a home, general purpose, DIY shop. It replaces a small suction blaster and a 6 scfm compressor that I had used for over 20 years. I also have a tractor that needs paint…badly. It is a 1942 AC-B. It has spent the vast majority of its’ life outside all the time in the elements of New Hampshire. It has very little original paint left on it. It is all sound metal but is definitely “rusty” brown, not pumpkin orange! I am planning a paint job on this tractor. I also have a dump body on one of my trucks that is rusted very severely, especially on the underside. I will NOT be sandblasting either one of these things. Why not? Neither one of these projects will ever be for “show” purposes. They are, however, work vehicles that I use all the time. Like everyone else though, I want them to look “nice”, even though I may be the only one that sees them…I don’t care about pleasing others…and I want to halt further deterioration of the dump body. If you have ever used a small suction sand blaster you already know why I am not blasting them. That equipment is reasonable for only small touch up blasting…you would be there literally for days on end trying to do a whole tractor to bright metal! Plus you probably would burn out a couple of small air compressors (2hp) along the way! While my current equipment is faster and better than the old suction blaster, doing jobs of this magnitude is still a real strain on the equipment (and my time). All the blasting I do is done outside. The blast grit is, for the most part, not recoverable. I could see myself easily going through $200-$300 or more just for the grit. I believe that “play box” sand is not as effective as commercial grit (Black Beauty) and I simply don’t bother with that stuff. So I limit my sandblasting to relatively small projects, spot rust areas, a plow frame, a fender here and there, a lawnmower deck…single item stuff like that. Attempting entire tractors is several orders of magnitude beyond the realistic capability of any DIY, IMHO. For me, hiring a commercial firm to do the blasting is not a realistic option either. I know of no firm in my immediate area that is equipped with a blast booth and the necessary heavy-duty equipment to do whole tractor blasting, even on a piecemeal basis. There is also that problem of transportation. I don’t have a flatbed trailer so I would have to hire that out also…twice (at separate times) I might add. Plus all the wheels should be off the damned thing anyway, and it should be stripped down so that it is not even in a running condition! Sandblasted steel is in a very raw state and needs to be primed right away since rusting begins almost immediately just from the humidity in the air…so the firm that does the blast should do the bare metal prep and the prime. Still more $$$. You could always consider doing the thing a couple of square feet at a time…blast, prep, prime, blast, prep, prime, and so on…but that seems to me to be such a cluster-@%$# arrangement that it is not worth more than a passing thought. Are you discouraged yet? Good, because I think there are some less-than-perfect alternatives available that you should consider.
I think you should start by reviewing the condition of any existing paint. Is it sound, no evidence of peeling, etc? I am of the opinion that decent sound paint should not be removed just for the sake of removal. You really don’t have to take the entire thing down to bare metal in many cases. If there are many coats of old paint buildup, with heavy, cracked and peeling chips though you should take everything off and start afresh.
First step is removal of grease and dirt buildup over perhaps many years of use. I grease my belly mower pitman bearing quite profusely and the underside of the tractor torque tube is always covered with thrown grease spatter. The reality of a working tractor :o). The tractor, at this point should be disassembled to the maximum practicable extent…fenders, hood, radiator shrouding, etc. removed. It can still be runnable and movable at this point however. My suggestion would be to start with the old putty knife and scrape away by hand to get the major deposits off. After that, try a commercial degreaser such as GUNK, sold in automotive supply stores for degreasing engines and engine compartments. It won’t work well on heavy, caked-on deposits so don’t bypass the putty knife work. You probably will have to apply it 2 or 3 times. If you have a pressure washer, so much the better, but a regular garden hose nozzle will work for the required water wash after application. I am told that oven cleaner works well also but that stuff removes paint too. If you have already decided you need to remove all the paint, fine. Otherwise hold off on the oven cleaner. After you get down to the existing paint all over you can make a better determination about the existing paint condition and whether or not you need to remove it all or just some of it.
If you need to remove it all, your options involve hard work, hard work and hard work. You can start with any readily available commercial paint stripper or try the oven cleaner. This can take several applications. You can also use a power disc sander equipped with a 24 grit “paint buster” disc from 3M. I have also found that Porter Cable makes a neat 6” diameter tungsten carbide disc that is intended for removal of house siding paint. It is available in most woodworking supply outlets and does a very good job without clogging up. It has a 7/8” diameter center hole and will work with many disc sander/grinders. It only costs about $12 as I recall and is well worth it. I have also found that the 2” and 3” diameter ROLOC sanding discs by 3M work great in pneumatic die grinders for getting into tight places. If all you have is an electric drill though, I am afraid you are pretty much limited to the chemical strippers…the speed of drills is not high enough to be really effective in this type of operation. If you happen to have a small suction blaster, here is where you can put it to good use…in any nooks and crannies that you can’t get at otherwise. That’s also good for any heavy rust in those areas. You don’t have to take to bright metal…just “brush blast” the relatively loose stuff away. Make sure that no grit can get into any openings that might provide a path into the engine or other internal areas that could be damaged, such as around the gear shift lever…the stuff flies EVERYWHERE. Power wire brushing works good, especially on the cast areas for loose surface rust and/or old paint particles. A 2” or 3” wire cup brush in a right angle pneumatic die grinder works good as do the 4.5” electric grinders with a wire brush, cup or otherwise attached. Eye protection is mandatory here. Those wire bristles can come loose and fly out!
Your approach from here should be different on the sheet steel parts than on the cast iron parts. You want to spend more effort on the sheet steel and less on the cast. The sheet steel, such as hood, fenders, radiator enclosure, etc. are the parts that are going to attract the eye. These are the parts that you want to get nice and smooth so the topcoat will have the maximum shine. The engine block, transmission and final drive housings, pto housing, etc are cast with a relatively rough natural surface, for the most part. You would be wasting your time (and money) trying to prepare these surfaces for any type of “mirror shine”. If you have dents and dings in the sheet metal, bang them out from the inside…but not enough to make any surface higher than the surrounding ones. Try to get everything to within about 1/8” of where it should finally be. You want to keep it lower for later filling with plastic filler. The purists will have a fit at mention of plastic filler. Don’t listen. If you want to mess around will dollies and body hammers (if you even have such specialized tools) or if you want to play with melting lead into the low spots, OK…but plastic filler works just fine, is cheap and is easy to use. You put the filler on AFTER you prime though. Repair work needed because of torn or missing metal is not covered here…that’s another subject altogether.
If your sheet steel is now bright clean metal, either from sandblasting or from paint stripping, you should treat with phosphoric acid. This is a two part process that has an apply, scrub, wash, apply, scrub, wash work sequence. It should be fairly easy to do since you have all the sheet steel off the tractor in separate pieces. DuPont 5717S and 5718S are the products. PPG has the same as DX579 and DX520. The scrubbing part is best done with a Skotchbrite pad. Use rubber gloves. You do not absolutely have to do this step…it is kind of messy…and there are primers available called self-etching primers that are promoted to eliminate this messy step, but I have no personal experience with them. I just think it is good thing to do if you have the steel in this raw condition, plus the materials are not expensive. This should be done even if there is no visible rust present. This process is NOT a rust removal process but rather a metal conditioning process for improved corrosion protection. The first step can actually remove slight recent rusting that may have occurred, say if your part got rained on before you could get it primed or something like that. Don’t expect it to remove any serious rust though…it won’t. It is not a rust TREATMENT process either. Don’t use it if serious heavy rusting is present…that’s another situation altogether.
At this point lets assume that your sheet steel is rusted and pitted quite heavily in some areas but in other areas on the same part the existing paint appears to be sound and you are not going to strip it. If the rusted areas are relatively small and you have rudimentary sandblast equipment, by all means blast what is needed and proceed as above with treatment of the blasted area. If, however, the rusted area is large…like on my B (most everything!), then I think you ought to consider treating the rust and then priming over it. Here again, the “restoration” purists will foam at the mouth at the very thought…but we are trying to be reasonably economical and practical here, right? I have tried two different products for this type of application: Rust-Mort by SEM Products, Inc. and Extend by Loctite/Permatex. I am not particularly impressed by Rust-Mort. It is a phosphoric acid-based product that is marketed as a “rust converter” and is to be applied over rust and then topcoated. The consistency is similar to water. The label instructions indicate that 3 to 4 thin coats should be applied with a brush. Have you ever tried to paint with water :o)? I found that you have to be very light on the brush…the stuff wants to run everywhere. It was not easy to get an even coat on a vertical surface and it dries very slowly. I am much more impressed with the Extend. Extend is marketed as a “rust treatment” and is some kind of polymer-based product that has a consistency similar to actual paint. It is applied by brush or spray in two coats and is fairly fast drying. It forms a relatively hard, black film. I used some of this stuff on the upper firewall and about half of the roof of one of my trucks that I painted last summer (I didn’t want to sandblast these areas). I would not recommend brushing it on in areas that you want a smooth surface, since it dries fairly fast, does not flow out that well and leaves significant brush strokes. Spraying works fine with light coats. Both products require wire brushing or some such method to remove any loose rust or flaking scale that is present prior to application. I do not have any long-term experience with how Extend works in this manner…ask me in 5 years. It does seem promising to me though and I intend on using it on the sheet metal of my own tractor and the dump body of my truck when I do those. It is available at NAPA and is not cheap at about $10 per pint ($80/gal). As I recall, the cost of the Rust-Mort is similar. For a technical data sheet on Extend, go here:
http://www.loctite.com/datasheets/tds/Extend_Rust_Treatment.pdf
There seems to be a number of people that don’t believe in using primers on bare metal. Maybe they think the paint companies are trying to rip them off by selling ‘em stuff they don’t need? Apparently they think they know more about paints than the paint manufacturer’s do. I have NEVER seen any topcoat paint from ANY manufacturer ever recommend NOT using a primer on bare metal. If you want to ignore the manufacturer’s instructions in this respect, you do so at your own risk.
You should be aware of three products that fall into the general primer category: primers, primer-surfacers and putties. Primers are sometimes also called non-sanding primers and/or primer-sealers. This is the type of product you should use on SMOOTH and treated bare metal, including sandblasted metal AND existing paint, after you rough up the existing paint by hand with 320 grit paper. It is also the product you should use on the cast surfaces. Using it over existing paint “seals” the old surface to assure there are no solvent or adverse reactions between the old paint and the new topcoat. For these purposes I use PPG DPLF two part epoxi primer. This is an excellent non-sanding primer that does not contain isocyanates. The problem is that it is quite expensive at about $135/gal RTS (ready-to-spray, after mixing). You might want to consider any other similar product that is listed as an acceptable substrate on the technical data sheet for the particular topcoat you are using...any of them should work fine for you at a more reasonable price.
Primer-surfacers are similar to primers but they are more heavily-bodied for a high film build and are fast drying. They are very easy to hand sand. They are used to fill in sandscratches and small surface imperfections, minor pitting included. This is the product you should generally use on the sheet metal under your topcoat. It may require two or more applications plus hand sanding with 220 grit between each to get the surface smooth. You MUST try and get these particular surfaces as smooth as possible. ANY imperfection in the surface will show through your topcoat…you want to minimize that…so spend the time here at this step. As with primers, you should carry the primer-surfacer over any existing paint and hand-sand everything with 320 grit or finer prior to applying any topcoat. A product I have had good luck with is DuPont’s 131S, “Fill ‘N Sand” acrylic primer-surfacer. I cannot recall what I spent for it the last time I bought any but it is not an awfully expensive product. Again, any primer-surfacer listed as an acceptable substrate on your topcoat tech data sheet should work well for you.
Putties are even more heavily-bodied than primer-surfacers. They are not sprayed on at all but are applied in (hopefully) small, spot areas with a rubber squeegee. They are generally the consistency of toothpaste and come in a tube. They would be used on any pitting or other imperfections not filled in by the primer-surfacer. After using any putty, I always like to spray a thin coat of primer or primer-surfacer over those areas so as to have a uniform-appearing undercoat for the topcoat. Again, hand sand everything with 320 grit or finer. 3M is well known as a manufacturer of putties for this purpose and their products are carried in most autobody supply places. For an on-line check on one of these putties, go here:
Link
If the pitting is real deep and not taken care of by a couple of coats of putty, try using some plastic body filler (after removing the putty). Use the kind that does NOT contain fiberglass strands...I think it is smoother.
Final step before applying the topcoat is to wash everything down with a solvent cleaner meant to remove any sanding dust and fingerprints from your carefully prepared surface. PPG’s DX-330, Acryli-Clean work’s good for this. Again, check for any recommendations on your topcoat data sheet. Tack-rag the remaining surfaces and apply your topcoat per the tech sheet application instructions. Then step back and admire your job as it dries!
Technical Data Sheets for DuPont products can be obtained here:
Link
For access, click on the visitor login button.
Technical Data Sheets for PPG products can be obtained here:
Link
This PPG site is hard to move around in. The info is there…you just have to find it by poking around. I hope the web page designers didn’t give up their day jobs :o). Here is an alternate site that is much easier for just the topcoat and primer products:
Link
If you haven’t sprayed any automotive topcoat before, I suggest you practice on a sheet of steel positioned so as to provide a vertical surface. You should get the feel for the application technique that is needed to stay between orangepeel and runs/sags before you put that final paint on your handiwork.
Good luck and have fun.
Rod
Rod (NH)
03-03-2002 08:22:43
Painting Part I - My thoughts
The following is an email that I sent to Tim concerning my thoughts on automotive type paints while trying to put things in some type of cost perspective. As time permits, I will try to assemble my thoughts on surface preparation, priming, filling pits, etc and post them here for information and consideration.
Tim, good info. I needed to know if I should steer you in the direction of automotive type paint or stick with industrial enamels or "tractor enamels" that you see in agricultural supply places. If you had said that you really did not want to go over $100, I would say stay away from the automotive stuff. I see no real reason why you can't go with the automotive paint though (it is superior, even the low end stuff) and keep under $500. You could go over $500 too but it is simply not necessary for anything but show projects that never see real world dirt or scratches or unless you just "want the best" and are willing to pay for it. Besides, the relatively rough cast surfaces of your tractor such as the engine block, drive housings, etc are not conducive to obtaining that mirror finish that the more expensive auto paints are capable of. Today's automotive paints come in at least two basic formulations that are used on cars and trucks by the refinish industry: enamels and urethanes. There is also a polyurethane that is used on trains, planes, fleet vehicles and high end autos...big $$$ there! The absolute best is the polyurethane. No staying under $500 here! DuPont's Imron is in this class. The second best are the urethanes...they have great gloss, color retention and chemical resistance. The high end ones are available only in automotive colors and it is unlikely you can get those mixed to any older tractor colors, except by actual sample analysis. There is a lower end version in this category that you can get mixed colors for tractors. It is debateable if you could stay under $500 here. Certainly not in the high end, but possible in the low end. This is what much of the auto industry is using now in basecoat/clearcoat configuration. Some are also available in single stage (no clear coat) configuration. DuPont's ChromaOne and PPG's Deltron are in this class at the high end. At the low end is DuPont's Centari (depending on how it's mixed) and PPG's OMNI MTK. The third best is the "hardened" enamels. These are (now-a-days) acrylic enamels with "hardeners" that improve gloss, color retention and chemical resistance. These hardeners basically modify the enamel into a semi-urethane. They are the most popular for general usage but have some significant safety issues that I will discuss later. If you have the right safety equipment, you can come in under $500 here, especially with the low end stuff. DuPont's Centari (depending on how it is mixed) is at the high end here with PPG's OMNI MAE at the lower end. While some may argue that these additives actually make the film harder and more resistant to failure from abrasion, my own experience tells me that it is not a very large difference. I once painted my 8' Fischer snow plow with an expensive polyurethane (PPG's Durethane at the time) thinking that it would last a long time. Was nice and pretty but I have to say that the rocks and dirt from plowing a dirt road scraped through that stuff as easy as if it were Rustoleum or some other hardware store paint...waste of money for me to use it for that application. The fourth best is straight acrylic enamel without the hardener. This really is an excellent paint and you certainly can come in under $500 here. It is not "bad"...just not quite as good as the hardened version. Let's just say the gloss, color retention and chemical resistence is "good" where the hardened enamel is "very good" and the urethane is "excellent". PPG's OMNI MAE and DuPont's NASON FastDry are in this class. The last real category is not really an automotive paint anymore. It is called, generally, an alkyd enamel. It is no longer mixed for any serious automotive use. DuPont's Dulux used to be popular in this category in the '50s. It is the most economical. I would put it in the same category as the "tractor paints" and the industrial enamels such as Rustoleum and "Impervo" by Benjamin Moore that you can buy in hardware stores and home centers. Some of the tractor paints may even have "hardeners" available...Dulux used to. These are still good paints, but on a relative scale with the above concerning color and gloss retention and chemical resistance, I would put them as "fair". Whereas the automotive paints above are formulated for spray only, these alykds are formulated for either brush or spray. If you had no ability to spray, these are what I would recommend. It would be similar to the original factory paint on your tractor...superior to anything you could get from a spray can IMHO. I cannot recommend spray cans to anyone for even the cheapest of projects...I simply think they are a waste of time and money. It seems you may have already found that out :o). The chipping that you mention though is indicative of poor adhesion and may have been due to inadequate surface preparation for the topcoat. Don't mean to write a book here. However, I do want to give you some background so you will see the basis for what I wind up recommending. I would like to recommend the hardened enamel but I really think you should stick with the straight acrylic...the fourth best stuff above. The reason has to do with safety. The hardeners have in them chemicals called isocyanates or polyisocyanates that are hazardous to breathe. The same holds true for the urethanes and polyurethanes. The chemical cartridge respirator that you have is not effective in treating these materials. If you read the very fine print on a hardener label you are likely to find that a full face air-supplied respirator is called for. If you have seen photos of painters in a spray booth painting a car wearing a complete hood and an entire white protective "space" suit, this is the reason why. An air-supplied respirator has a separate compressor, usually non-lubricated, that supplies fresh, uncontaminated air directly to the facepiece. This equipment is fairly expensive. As I recall, I paid several hundred dollars 15 years ago for mine. The reason I got mine was I sprayed some hardened enamel on a couple of cars with only the cartridge style respirator. Bad scene. I spent two or three days coughing severely and not being able to take a deep breath...it wasn't worth it. It is for this reason that I cannot recommend the hardened enamel to you...I do not think you have the necessary equipment to properly protect your repiratory system. It is your choice however. You do not need any type of spray booth. I use an open air one...the great outdoors. I can only spray on good days that are not windy and I don't like to paint in direct sunlight. But I am not in the "business" and can work my few jobs around the weather. The only thing detrimental to this besides scheduling is the probability that a few bugs will get in the paint before it dries. That will happen and there is not much you can do about it except leave 'em there. If you try and remove 'em you'll just make things worse. Don't do any painting during the heavy mosquito season :o). The paint that I intend to use on my own tractor (hopefully this year) is the same one I will recommend to you. It is an acrylic enamel that can be used with or without hardener. It is made by PPG under the OMNI label and is available at any automotive paint supplier that carries the PPG line. If you want to use a similar DuPont product for whatever reason, that should be the subject of a separate discussion. My experience is with PPG and DuPont. There are others with similar products but I don't know enough about them to make an intelligent recommendation. I assume you are going to use it on a Case? Do you have the Case paint code for the color you want? You will need to confirm with your supplier that the OMNI enamel can, indeed, be mixed to the color that you want. For technical data sheets from PPG on this enamel go here:>Link
Rod
mark bishop
03-13-2004 06:59:41
 Re: Re: First paint job , need advise in reply to Rod (NH), 03-03-2002 08:22:43
Wow, great information, thank for all the tips etc BEFORE I start my project (1930 Regular)
Regards.
Keith B
03-04-2002 07:27:28
Very informative for those of us with little to no experience. (I put myself in the NO Experience category)
I'm hoping on painting my tractor (Farmall 560) sometime this year, but thought I would first practice on a couple of different implements like my brush hog and a two back blades before I go for the tractor.
I'm also impressed that you did not pound home the need for the high end paints. My brother-in-law paints cars for a living and I once asked his opinion and by the time he was done, there was more in paint and equipment than I paid for BOTH my tractors combined!
My goals is to first protect the metal, second make it look good(or at least better than it does now). And third, have fun doing the work myself.
Thanks for the informative post
Keith B
03-04-2002 07:27:10
I'm hoping on painting my tractor (Farmall 560) sometime this year, but though I would first practice on a couple of different implements like my brush hog and a two back blades before I go for the tractor.
Rod (NH)
03-04-2002 20:43:57
 Re: Re: Re: First paint job , need advise in reply to Keith B, 03-04-2002 07:27:10
Hi Keith,
Thanks for the kind words. Great idea to practice on the implements, especially back blades. They will give you a nice broad vertical surface on which to find out how heavy you can apply without generating runs and sags. Ironically, the expensive urethanes are really a breeze to apply I think...easier than the enamels. One thing you will likely find with both alkyd and acrylic enamels is that you are walking a tightrope between applying it heavy enough to flow out well, avoiding excessive orange peel and getting it on too heavy and winding up with runs and sags. The trick is to get it just right and that takes some practice. Usually for enamels you give it just enough time to get a little tacky between coats.
Everybody’s situation is usually a little bit different and what might be best for me may not be best for someone else in a particular circumstance. Certainly $$$ enters into the picture for most people and compromises have to be made. Putting a thousand dollar paint job on a working tractor is not necessary in my opinion for it to look "good". My neighbor down the road a-piece maintains his Cat backhoes and Michigan loaders very nicely with a brush and a few gallons of Cat paint :o). They look good to me. To each his own though.
You have realistic, reasonable goals and I am convinced you will make it look good indeed.
Have fun and take care.
Rod
Rod (NH)
03-01-2002 14:57:50
Hi Tim,
You have asked questions that can have different answers...and different opinions. I will try to give my own personal ones. First though I think you need to establish how much you are willing to spend, in total, on materials and also evaluate what equipment you have available to you to apply them. I am going to assume that you do not wish to buy additional equipment and that you have a basic spray gun and an air compressor that can properly supply it, including some type of rudimentary respiratory safety equipment but NOT a supplied-air respirator. You should not feel pressured by anyone to spend more than you are comfortable with in order to get a "better" job. I am of the opinion that you can achieve a fairly decent paint job on a limited budget. It won’t win any prizes at tractor shows...but that is not your goal, is it? Give me an idea of your material budget...under say $200 or do you want to go higher? Is your spray gun the external mix type? Give me an idea of what you have for available equipment. If you are confused with some of the terminology, just ask. Then we can continue on with the more detailed stuff if you wish. Also, read back a ways in this forum. You will see a discussion on phosphoric acid treatments among other things that you might find useful. For now,
Rod
