Anyone used hobbyair?
Daniel H.
07-12-2005 09:32:27
After reading all the dangerous stuff about isocyanates, I'm wondering if a forced air respirator isn't the way to go. I found a hobbyair with half mask and pressurized hood around $400.00. Are these good enough for occasional use?
Also, I was planning to use Delstar Enamel to stay away from the isos. but the hardener for it is iso. based. Since there are going to be isos. either way, would it be better to use a single stage urethane? Which PPG product would work?
Thanks, Daniel
CNKS
07-12-2005 17:13:00
 Re: Anyone used hobbyair? in reply to Daniel H., 07-12-2005 09:32:27
Any PPG product will work. Delstar is more expensive than the Omni line. Omni acrylic urethane is somewhat better than Omni acrylic enamel, neither is as good as Delstar. I've never used Delstar because of the expense, only Omni. Concept is even better, but you will need a loan. I have a Hobby Air, it works fine. Mine has only a pressurized hood, no mask. Whichever way you go, don't use only a half mask, as iso's are attracted to moisture, namely your eyes.
