herschel-adams paints
gary case
07-16-2005 08:54:01
i'm using some average quality paint from herschel-adams alkyd enamel. can i use napa's 252 standard hadener with itand can i clear coat this paint. thanx gary
russ1
07-18-2005 06:54:24
 Re: herschel-adams paints in reply to gary case, 07-16-2005 08:54:01
Gary. I am currently using the Herschel Adams paint on an Allis Chalmers. I used hardener that I purchased at Tractor Supply that is compatible with the alkyd enamel. I believe it is valspar. $10.00 for enough to treat a gallon of paint.
I don't know about the NAPA hardener.
Russ
gary case
07-18-2005 16:37:58
 Re: herschel-adams paints in reply to russ1, 07-18-2005 06:54:24
thanx russ,ya i think i'm going check out that napa hardener or at least go another napa. this guy said i only nee about a capful. and like you said the hers hardener takes the whole thing.napa 254 standard hardner $21 and some change.same size can. did you have any previous use of this paint? would you or can you clear coat on it? thanx again. gary case
russ1
07-19-2005 05:11:27
 Re: herschel-adams paints in reply to gary case , 07-18-2005 16:37:58
This is my first time to use it. I assume that you could clear coat it. Since mine will mostly be inside I never considered it.
Russ
