Best finish advice needed.
Chad (IA)
07-17-2005 07:00:38
Experts, I will have my Oliver 1655 painted next summer and need to start considering paint. I will use Martin Senour Paint and have the paint codes and decals from the Dumonts. What type of paint and hardener do I use for the absolute best shine finish? Money is not a concern. Chad (IA)
CNKS
07-18-2005 09:15:53
 Re: Best finish advice needed. in reply to Chad (IA), 07-17-2005 07:00:38
Haven't used it -- money is no object? Buy the most expensive they have. Their "economy" acrylic urethane (single stage) would be ok, though. Someone familiar with Martin Senour can give you the details.
Illinois Boy
07-18-2005 10:42:18
 Re: Best finish advice needed. in reply to CNKS, 07-18-2005 09:15:53
Money is not a concern??
Can I move in with ya' ?????
Chad (IA)
07-18-2005 12:24:31
 Re: Best finish advice needed. in reply to Illinois Boy, 07-18-2005 10:42:18
OK. Let me rephrase, I don't mind spending a couple hundred more dollars on paint if I get a good looking top coat.
Cliff Neubauer
07-20-2005 11:03:08
 Re: Best finish advice needed. in reply to Chad (IA) , 07-18-2005 12:24:31
With PPG paints you can mix clear coat into the top coats of their single stage urethane paints, I did that on our 706 and it really gave it a deep shine. The first three coats were regular urethane paint but on the next three coats I think I mixed up to 20% clear in and then color sanded to give the paint a really deep look at a lower cost than a full base coat/clear coat paint system would have cost.
Jack Mc
07-20-2005 21:25:01
 Re: Best finish advice needed. in reply to Cliff Neubauer, 07-20-2005 11:03:08
When you say single stage Urethane does this mean you use no hardener or am I mis reading here. And if so would you not need hardener for the clear? Would like to find a way for a good hard finish, glossy but still not use hardener. Too many scary stories out there on isocyanates. Jack
Rod (NH)
07-21-2005 18:11:52
 Re: Best finish advice needed. in reply to Jack Mc, 07-20-2005 21:25:01
Hi Jack,
A single stage paint doesn't require a clear coat to obtain the gloss. It has nothing to do with if a hardener is used or not. It's a term that has come about since the use of basecoat/clearcoat systems where the basecoat provides the color but is relatively flat and requires a separate clear coat to get the gloss. That is sometimes called a two stage paint for that reason. All urethanes use an isocyanate-containing hardener. That includes the single stage paints and the clear coats used with bc/cc systems. At one time DuPont marketed a non-iso clear. They may still have it. I have never used it so I can't comment. The vast majority of clears require an isocyanate-containing hardener
Be aware that the hardeners used in two-part acrylic and synthetic enamels also contain isocyanates. You can avoid isocyanates by using the tractor paints and some automotive enamels that do not require a hardener additive. Of course you loose the advantages of using a hardener. You can still get a very good gloss but fixing errors are a problem and the chemical and fade resistance and gloss retention will not be as good. You are correct about avoiding isocyanates unless you have a fresh air breathing system. Getting such a breathing system should really be the first priority for anyone serious about using modern paints.
third party image Rod
Jack mc
07-21-2005 20:02:38
 Re: Best finish advice needed. in reply to Rod (NH), 07-21-2005 18:11:52
Thanks Rod- that cleared that up for me. Am always looking for a paint that doesn't require such expensive backup equipment that will have some lasting power. Doesn't work does it! Live in Arizona and paint is terrible to fade here. Jack
