CNKS
07-19-2005 14:52:39
Re: IH red in reply to RustyFarmall, 07-19-2005 07:42:49
I may have to switch to CIH 2150, if I can't figure what the problem with Omni is, or else move up to Concept, still with no guarantee my dealer won't screw something up. 2150 has the advantage that it is premixed, and is more or less consistent from batch to batch, although I have heard of problems with it also. The reason some of us like higher quality paint is that we spend days, weeks, and in my case, months preparing a tractor, not just for paint, but the mechanical aspects also. I completely strip the old paint, rust, what ever off, every part I can get off the tractor comes off and is repaired if need be and treated separately as far as paint goes. Each part is primed with epoxy primer, and nearly all non-cast parts get multiple coats of a sandable surfacer so that the surface is absolutely smooth. After all that time and preparation, most of us think nothing of spending 2 or 3 times the price of CIH 2150. Case IH has only one primer, one primer does not necessarily fit all situations. I prefer to use multiple products that are all compatible with each other. I'm not saying that 2150 cannot be used in this situation (again, I may have to) but synthetic enamel simply does not have the quality of even the cheaper paints by PPG, DuPont, etc. If it did, all the car manufacturers would be using it. No tractor or automobile manufacturer uses synthetic enamel anymore, with the possible exception of the finish on things like a car trailer I bought a couple of months ago. 2150 does not come in acrylic urethane, which can be color sanded and compounded the next day if necessary, a procedure I don't care for, but with my limited painting skills is sometimes necessary. Acrylic urethane will hold it's color for years. I understand that whoever makes 2150 now has a hardener for it, if hardener is not used, what you see is what you get, it can't be corrected for months. I like for it to be perfect, don't always get there, but I try. Paint to me is primary, not secondary as it is to many people. The mechanical part is primary also, although I don't completely restore the mechanical part -- that is cost prohibitive, for me anyway. I would rather have rust than a lousy paint job. I have bought two tractors with 50-50 paint jobs--looks good from 50 feet away at 50 mph (I would have paid MORE for rust, because I have to remove all the new paint and start over) or in someone pictures -- pictures don't show the detail. Only my opinion. Each person is free to do as he or she wants. If it suits you it suits me.
