Rusty Jones
11-25-2001 18:48:55
Re: Re: Re: Re: Re: Re: Re: Before Bondo in reply to Bill, 10-13-2001 07:54:06
Well, fellers, most of your comments about leading body panels are right on the money, but the best lead mixture was 60/40, in sticks. Trying to use plumbers lead was like trying to push a wagon up hill with a rope! Plumbers lead took too much heat to soften it, and when it got hot enough, it ran off. The 60/40 mixture let the worker heat it until it got soft, then he could push it around and sort of smooth it out. After it hardened, it was filed with a curved tooth file, then block sanded to finish it off. Caution! Don't try to "pick up" the really lowspots--put on a bit more lead. Also--Bondo won't stick to lead very good! I found several leading paddles at the flea market, got them for $1:00. I had a leading tip that went on the end of the acetylene torch that didn't use any oxygen, just the gas. It had a large area flame that was just right for heating the lead. I think my son absconded with that, as he's doing body work, too. Two reasons why we quit using lead and went to Bondo--the cost got too high, and the car makers lightened the steel in the car. The heating process made that light guage tin warp excessively, so we had to quit using it. Those cars made before 1950 could be leaded without all that warping, as they had panels made with compound curves, not flat like the cars from 1950 on! From: Rusty jones
