Question about Orange Peel
Charles Park
07-25-2005 07:33:39
Well, seems like I can not paint without orange peel.
Have been experimenting on the hood. After I wet sand, I can buff the orange peel down to a dull flat finish and then compound it back to a nice red and shinny finish.
My question is how would you normally do this? Should you be able to paint and then buff it out without sanding? Or must you sand every time?
BPNT
08-04-2005 21:15:59
 Re: Question about Orange Peel in reply to Charles Park, 07-25-2005 07:33:39
As I've said before, use non-HVLP guns, a big compressor, put an extra coat of paint or clearcoat on, and sand with 1200grit, buff, and polish. If you are trying to match the texture of a 2005 Chevy pickup (heavy orange peel) no buffing is required. If, however, you are trying to produce a show-quality tractor, plan on buffing. Anyone who claims to be able to produce show-quality results without buffing is either my brother-in-law or a liar.
Joe(TX)
08-04-2005 05:18:33
Orange peel is caused by either too much pressure, holding the gun too close, or not thinning the paint enough.
Rod (NH)
07-25-2005 09:56:21
Hi Charles,
If the paint is applied properly, using the ingredients recommended by the manufacturer, there should be no need for any sanding or buffing. In fact, many tractor parts do not lend themselves to color sanding and buffing due to the configuration. Color sanding, almost always done wet due to the extra fine grits involved, and compounding/buffing should be left to those instances where correction of an application error (e.g. excessive orange peel) is required and is feasible, or where the absolute perfection of a true show piece is desired. If you find that you continually have unacceptable orange peel, you should look to improve your application methods. Whenever I get some orange peel that is too much for my liking, I generally sand with 400 grit and reshoot the color instead of going the sanding/buffing route. I find that to be an easier and faster corrective action. While it is true that another color shot will provide another opportunity for orange peel, you also have to understand that if the sanding/compounding is a little on the agressive side, you can cut through the color into the primer unless you are very careful on ridges, edges or other change in profile. So there are risks with either approach to correct things. The above is only applicable for hardened enamels and urethanes. Correction of application errors with unhardened enamels can be more of a problem.
third party image Rod
Charles Park
07-26-2005 06:30:43
 Re: Question about Orange Peel in reply to Rod (NH), 07-25-2005 09:56:21
Thanks. I will try to work on my technique and take this as an inspiration to try to do better work.
I think I have been putting on too much paint. Thin coats and let each one dry completley?
This tractor is special because it belonged to my grandfather. Plan to take care of the M for the rest of my life and drive it in parades and that sort of thing.
Rod (NH)
07-26-2005 17:52:29
 Re: Question about Orange Peel in reply to Charles Park, 07-26-2005 06:30:43
Well, it depends on the actual paint. I don't know what paint you are using. If it's a synthetic enamel with no directions on the can label I can't help you much. It's been over 40 years since I used any of that stuff. As I remember, you'd put down a fairly light "tack" coat and follow it with a medium to full coat after some period - usually when the surface became a little tacky. But I can't be sure - it's been so long. The modern automotive acrylic enamels and urethanes indicate on the tech sheets about how long to wait between coats. Those are much faster drying paints and the time between coats is typically 15 minutes. That may be too little for the old synthetic enamel. When I use the OMNI MTK acrylic urethane (or even an acrylic enamel), I generally apply a medium coat right off the bat to essentially cover and follow with two other medium coats after the time periods specified in the tech sheet. If you are using a paint without a tech sheet and don't have such information, you'll have to find a decent procedure by trial and error or from someone who uses that type of paint successfully. You should not let the paint dry completely between coats - you will not get good adhesion between coats w/o intermediate sanding if you do. Plus lifting can be a problem with such a practice if a hardener is not used. I know that the terms light or medium or full coats are not very descriptive - it's just something you'll have to learn by doing. Sorry. It's usually a fine line between orange peel and runs and it takes practice to gain confidence with it.
I think Seth (IA) does quite a bit of work in unhardened synthetic enamels. He would be a better one to provide some guidance for spraying that type of paint - if that's what you are using. He may see this and post here or you can start a new topic with his name in it and ask him.
I'm glad you are painting a family tractor. It somehow means a lot more that way. I know just how you feel.
Charles Park
07-25-2005 11:11:22
Rod, you are a true treasure! Thanks. I want the tank, hood to be just about perfect and very shinny. The rest can be cast iron red. You are always helpful.
Rod (NH)
07-25-2005 19:42:55
 Re: Question about Orange Peel in reply to Charles Park, 07-25-2005 11:11:22
Well, it's my opinion. Others will disagree. I just think that there are too many that are understandably eager for that perfect job with only a little practice in application. They wind up neglecting their technique in favor of after-the-fact corrective work that might not have been necessary otherwise. Hoods and fenders are probably the easiest tractor parts to compound but again, it depends on the actual configuration. Many tractor parts, even some sheet metal areas, do not lend themselves as easily to power compounding as an automobile hood or door panel where the contours are broader and usually more regular. Leaving some excessive peel areas intact because of an inability to effectively get at and compound them is poor, I think. I suppose working through extremely fine (say 2000) grits by hand and compounding by hand in such areas is a possibility but would not be something I would look forward too. There are better ways to spend your time :o).
Take a look at the basic causes for orange peel to see if you can try to eliminate most of it and avoid the final sanding/compounding bit altogether. In the end only you can decide how much peel, if any, is acceptable. During painting one of my AC-B fenders recently I got a little peel in the final clearcoat after essentially a near perfect application of the color. It happens - but it was my own fault - I think I was holding the gun a little too far away to avoid runs at the last step. Too cautious of me. Anyway, it was not serious enough to do anything about. I could have sanded and compounded but I didn't want to bother. I could also have sanded and reshot a couple of coats of clear but didn't want to bother doing that either. Of course this work is for myself and I am not in it to please anyone else or to enter show contests. It only matters that I am reasonably pleased with my own product - and only I can decide that.
CNKS
07-25-2005 12:41:26
I have had the same problem as you. Mine is caused by overspray on the curved surfaces, landing on the fresh paint of the last pass or so -- in other words, you need to hold the gun perfectly perpendicular to the surface, hard to do on small surfaces such as a gas tank or hood. I attempt to get around that by using a smaller tip. For HVLP a 1.3 mm, rather than a 1.5 etc -- Not a cure all, but it helps. That means more passes, thus more chance of messing up, but a 1.3 is not that much smaller than a 1.5. Conversely, I have a touch up gun with a 1.0, another with a 1.3; the 1.0 is a little narrow, and I sometimes miss the desired 50% overlap with it. The other, and best way is to get as much experience as Rod has.
Rod (NH)
07-25-2005 20:02:56
 Re: Question about Orange Peel in reply to CNKS, 07-25-2005 12:41:26
Are you sure you are laying down a wet enough film? I would expect any overspray to easily melt right into the surrounding wet film in the type of situation you mention. Especially if you are doing a single part like a gas tank where the total pass time is short. That red should cover pretty well. You should be getting "near complete" coverage on the first coat. Certainly fully complete on the second - just to pick up any minor areas that may still show through. The third coat is for good measure, at least that's the way I treat it with the MTK. If you are not fully covered by the second coat, you may not be applying it heavy enough. Have you tried stepping up to the next hotter reducer to see if that can minimize the problem? I am just speculating here because I can't say that I have ever noticed an overspray problem except on previously painted (and dried) surfaces that were not properly masked off. I know there can be an issue with large cars or trucks where you have to get around the vehicle in a time fast enough for the last paint down to melt in well with the first paint down in each coat. But I doubt you are talking about anything like that.
CNKS
07-26-2005 05:08:23
 Re: Question about Orange Peel in reply to Rod (NH), 07-25-2005 20:02:56
You may be right. The problem I referred to occurred at about 70 degress with MR 186 reducer, which I believe is in the correct temp range -- you can correct me. I believe the film was wet enough because I was painting almost to the point of runs and sags. The sides looked perfect with virtually no orange peel. My thinking is that the problem is my technique. I also believe that your non-hvlp guns have a wider pattern than mine, and that you can cover a larger area, perhaps getting back to it faster than I can, or perhaps due to the wide pattern, you get a certain area covered in one pass where it might take me two. (This conflicts with my earlier response, but I think it can go both ways). But, my main problem is that I don't paint often enough to develop a technique. I answer questions about procedures and types of paint -- that does't mean I'm an expert at knowing how to use them. Only way I can do that is more experience.
Rod (NH)
07-26-2005 18:36:13
 Re: Question about Orange Peel in reply to CNKS, 07-26-2005 05:08:23
MR 186 should be fine for 70 or even 70+ some. It's the most common reducer I use for MTK. PPG doesn't do well in recommending temperature ranges for their additives in the OMNI line. Fast, medium, slow, etc. are not that descriptive. I have asked PPG before on the matter and got a non-responsive answer. Here's my own crude numbers for reducer and hardener that I have penciled in on the tech sheet:
MR185 - 60-70 deg F
MR186 - 70-80 deg F
MR187 - 80-90 deg F
MR188 - 90+ deg F
MH167 - 60-75 deg F
MH168 - 70-85 deg F
MH169 - 80-95 deg F
If it seems to be in the higher end of a range at the time of painting, I may choose to use the next hotter product. However, I wouldn't go hotter than MR186 at 70 deg. Since I do everything outside and am extremely dependent on the weather, I keep MR186, 187 and MH 168 on hand as the most likely to use. I don't like painting at all below 70 or above 85.
The gun I've been using for all the work on my AC-B so far has been my spot gun. That's an HVLP model so I doubt it's an issue of HVLP vs. non-HVLP. For a spot gun it has a good sized pattern at 4-5" but it's still less than the typical pattern for a full sized gun. I don't think it's an issue of pattern size either. Perhaps I am confused with your use of the term "overspray". To me, that suggests a dry, rough spray rather than orange peel. If your problem is a little orange peel in your "overspray" areas, then you are probably correct although I have not noticed that as a problem as far as any overspray is concerned. I think my own problem with orange peel in the clear resulted from holding the gun too far away and having too fast a travel speed - on a consistent basis. Not getting enough material down quick enough and wet enough to permit the best flowout on the first coat. I noticed it and tried to correct by compensating on the second coat but failed in the effort. I suppose if you are at a poor spray angle, that the overspray that you mention can result in the same effect as being too far from the surface. I have just never noticed it. I would expect the overlap on the next pass, which should be within seconds, to melt it in well - that is unless the next pass is also to far away for some reason. I have not had an orange peel problem with the MTK or even with the MC on any of my AC-B sheetmetal to date, including the gas tank - except that once with the MC on the fender. Anyway, I don't have an answer to your problem.
CNKS
07-26-2005 19:42:00
 Re: Question about Orange Peel in reply to Rod (NH), 07-26-2005 18:36:13
I think it is simply a matter of not enough practice. I implied that I had orange peel when I responded to the initial post. The term overspray, or dry spray is probably more appropriate. When I spray a hood, I will typically start at the bottom of one side then work up the side, over the top and down the other side -- lengthwise, not crosswise. I am probably ok until I begin to work down the opposite side, then at the final curve of the hood, "overspray" can (not always) strike the newly painted top surface at the wrong angle, resulting in about the same thing as happened to your fenders, only worse. Actually, spraying the hood crosswise might help, provided I can keep the gun perpendicular as I go around. On a long hood that means more, shorter passes, and for me, more chances to screw up -- but, I have done that on a grille with pretty good success. The person who suggested the smaller tip is a person, who, like yourself, has painted for a long time -- I used to correspond with him by email. Only difference is that he uses the same HVLP gun as I do, he also likes PPG Omni. Otherwise you two are on the same page, all of the time.
Rod (NH)
07-27-2005 16:47:30
 Re: Question about Orange Peel in reply to CNKS, 07-26-2005 19:42:00
I find your problem somewhat interesting simply because I don't think I've ever experienced it. I would never think of doing a hood perpendicular to the long side - it would seem to be oh, unatural to me :o). The only time I've gotten into doing a hood crosswise is with my truck - and then only because the Centari that I was using at the time recommended a cross-coat technique where the second coat is applied perpendicular to the first. I think that's kind of wierd since I believe it is impossible to do on a full sized vehicle with the hood in place. My arms are not six feet long. Most people's arms are not that long either. The hood I did was done off the vehicle so I could do the cross-coat technique fairly easily. I did my B hood from the tractor similar to the way you mention. Lengthwise passes starting at the middle of the top, proceeding down one side, then moving to the other side and beginning where I left off in the middle of the top, continuing on across the top and down the other side. No problem with either orange peel or dry spray. I was using my spot gun because the size didn't warrant setting up my full sized gun with pressure pot. Actually that sequence is not much different from doing a car - top down - for instance the roof first, then the hood and trunk, then on to the sides. Inevitably, in doing the sides after the hood, around the fender areas, there will be some "overspray" get onto the previous painted hood areas at a less-than-perfect angle that puts the gun-to-surface distance a little more than desired. The extent of that would be greater with larger fan patterns. I just haven't had a problem in doing it that way, even with a 14"-15" large pattern on a VW beetle. I suppose one could start the hood by doing a full pass down the top side on the fenders, then up and over to the center of the hood and repeating on the other side - then go back and finish the lower portions of the fenders. In other words, ending in the middle top of the hood rather than starting there. I have never tried it that way.
It would seem to me that no matter how you approach it, transitioning from a vertical surface to an attached horizontal surface (or vice-versa) will result in half the pattern falling on a just painted surface at an angle that is not perfectly perpendicular and therefore a little farther away than "normal".
Another thing I read about not long ago was the recommendation to use a greater than normal overlap for HVLP, in addition to a closer gun-to-surface distance and a slower travel speed. More like 70% (?) than the standard 50% overlap. I have 50% engrained in my thinking and simply continue it with my spot HVLP with no noticeable problem although I do try to get a little closer and travel slower than I am otherwise used to.
My guess is when you go down from a 1.5 tip to a 1.3 tip you will decrease the paint flow rate, assuming the same paint viscosity. I don't think the pattern size will change automatically unless you choke down on the fan control knob. To keep the same application rate with the smaller tip and w/o changing the fan control, you might try slowing down your travel speed a little to see if that helps. You could also try cutting back a bit on the air pressure at the gun (say 5psi), especially with the smaller tip, since less paint per minute means less required air per minute to atomize. If you haven't already done so, you might want to check your atomization and pattern shape by rapidly triggering the gun on and off for just a fraction of a second on a piece of cardboard just to verify a smooth, uniform pattern that does not take on an hourglass shape. I can't think of anything else to suggest.
CNKS
07-27-2005 17:20:33
 Re: Question about Orange Peel in reply to Rod (NH), 07-27-2005 16:47:30
I think my gun is set up right, and I always do the cardboard thing, mainly to make sure one side of the air cap is not plugged. I haven't used the 1.3 much, certainly not on the last hood I did. I think the pattern is a little smaller, I need to compare when I start painting again. I have not heard about the 70% overlap, the person I corresponded with knows his stuff, and would have told me. Regardless of tip size, he recommends INCREASING the pressure 5 psi for better atomization, leaving the fluid alone, it is maxed out anyway--I have done that, but don't notice any difference. But, I may do what you say and decrease the air pressure, need to practice some first. As I say, on flat surfaces I don't have any problem. As to increasing it, the implication is that the 10 psi tip pressure is because of enviornmental regs, increasing the gun pressure slightly results in better atomization, if that (enviornmental) is not a concern. But, you are then beginning to defeat the purpose (less wasted paint) of HVLP. I have thought about starting in the middle of the hood, as you say, but I thought that might not be wise because you are not immediately doing the overlap on the other half of the 1st pass. In other words, I thought it would be too dry, but it doesn't take long to do a small hood. However, then I get two chances for the overspray, one on each side of the hood. The 460 hood I'm going to do next is long, I think it exceeds 4 feet. That one is going to be interesting. I'll keep your suggestions in mind --Thanks.
Rod (NH)
07-27-2005 19:18:20
 Re: Question about Orange Peel in reply to CNKS, 07-27-2005 17:20:33
Oh, I'll certainly agree that for better atomization, increasing the air pressure at the gun would be the correct way to go if needed. Even if you wind up exceeding the manufacturer's stated maximum 10 psig "at the cap" for HVLP. That is, unless you are in an area and a situation where legal compliance is the prime consideration. So far, with my somewhat limited experience with my HVLP spot gun, I have not found the need to either increase or decrease the gun air pressure from the stated maximum. However too high an air pressure for the paint flow can be a cause of dry spray - if, indeed, that is part of the problem.
I can't remember where I read the 70% and I am not even sure it was 70%. But it was greater than 50%. Here's what Dr. Gun at Sharp says:
"Here's a recap when spraying with HVLP
Depending on the brand of spray gun, you will see a wide range of inlet pressures to equal 10 PSI @ cap. Having enough CFM is critical. Spray at a closer distance. Use a faster stroke. Use a higher percentage of pattern overlap. On larger re-spray areas, never use faster than the medium temperature solvents; especially with high solids clears. Low noise doesn't mean slow gun speed. High solids, low VOC does not constitute high viscosity. Spray a balanced gun, i.e.: air to material ratio. The use of HVLP is just what the Doctor ordered. Don't buy it unless you can try it."
The recommendation to not use a fast reducer, apparently even if the temperature calls for it, is a new one for me. I haven't made any changes in reducer selection whether I use my HVLP spot or my non-HVLP full size. The MC161 HS clear that I use doesn't call for any reducer generally but does permit up to 10% retarder (again, if needed). I hadn't had a problem prior to the fender but I'll have to keep that tidbit in mind for a possible try the next time.
There shouldn't be a problem with matching up to and melting in with a pass that was done previously as long as the time is not too long. Think of doing a '60s full size Pontiac car hood in place - w/o touching the fenders with your midsection. You can't get all of it from one side. You have to do it halves from each side - unless you have those six foot long arms :o). That four foot long hood should not be a problem either. Plus it's probably narrow enough such that you can do the entire top and one side from one side if you choose. I just don't think it's the procedural things that are causing your problem - but I also don't know what might be.
CNKS
07-27-2005 20:05:13
 Re: Question about Orange Peel in reply to Rod (NH), 07-27-2005 19:18:20
I have a lot of small parts to experiment on, including one smaller piece that covers the gas tank, and has the same curvature as the hood, that I am willing to repeat a couple of times if I have to. Again, I think it is just technique. I'll figure it out. The hood is the only thing that may cause problems, gas tank is covered, but I'm going to paint it, grille is simple, other panels are flat, etc. I occasionally read Dr. Gun, never seen the reducer thing either, the rest of his statements are standard painting procedure. Except that he does recommend increasing pattern overlap. Like you, I don't know if I buy that one.
Rustyj14
08-18-2005 15:47:15
 Re: Question about Orange Peel in reply to CNKS, 07-27-2005 20:05:13
CNKS: Been reading your statements about orange peel. i began my auto body work experience in a shop that refinished cars and trucks. After gatting over the initial shock about how much i had to learn, things went along better. Later, i learned all about priming the bare metal and repaired areas, and sanding with wet-or-dry paper. I eventually got to paint with laquer finishes. The shop did baked enamel refinish jobs, with a gas fired oven. After a year or so of laquer painting, the regular painter got sick, so, being on a time limit for the car in the spray booth, the boss told me to go in and paint it. With synthetic enamel!! Uh, oh! And, to boot, it was a hi-metallic gold color! And, thats when i found out why the regular painter downed several hookers of rye whiskey and several beers, before starting to paint! Said it calmed his nerves! Well, shaky nerves have ruined many good refinish jobs! And, being too careful,or poor memory of where and how much paint you have already applied in certain areas, causes either runs or sags, or orange peel or flooded areas, which causes wrinkles, when the top coat dries before the lower coats! I learned a pattern for car painting that resulted in very good jobs. I gave the roof a single coat, then , starting at the front edge of the right front door,at the bottom, went all the way around the car to finish up where i started. Also, starting at the bottom of the doors and fenders and working up kept the paint from running, in case i had to refill the gun. Second time around was a double coat,including the roof, and also the final coat.It is advisable to avoid heavy coats at door joints, etc. I finally got to where i could duplicate factory finish on any or all parts! Very seldom did i get runs or sags, because i was in a closed booth and had no distractions! any one who had the temerity to open the spray booth door when the fan was running, got a face full of paint, pronto! So, it is all paying attention to the job at hand, getting practice before trying to paint yer car, truck, or tractor, paying attention to details, and now, having the correct breathing equipment for painting! Rustyj
