Rod and CNKS
Charles Park
08-08-2005 04:03:32
Well, I took Rod's advice and focused on technique. Not much orange peel and was really pleased with the results there.
Did get solvent pop? Any way to solve this without a wet sand and compound? Oh please let there be a way!
CNKS
08-08-2005 17:04:55
 Re: Rod and CNKS in reply to Charles Park, 08-08-2005 04:03:32
Below is a link the Rod provided, he may have added comments. For some reason I haven't had that particular problem, had some of the others though.
Rod (NH)
08-08-2005 16:59:58
Charles,
I doubt your problem is going to be corrected by wet sand and compound. You can try but I wouldn't hold out a lot of hope. It sounds like it is either solvent pop or fisheyes from your description. Unfortunately, the most likely fix for either is probably a good sanding (if not complete stripping) and recoating. You should try and determine the cause though in order to avoid it from happening again.
third party image Rod
