Any products available to compensate for heat hum
jdk71
08-18-2005 10:44:37
At what point does the temperature and relative humidity become too high for painting? I am utilizing acrylic enamel paint with hardener and was wondering if there is a product which can be added to compensate for the humidity problem to allow the paint to adhere and the spray gun to work properly. My painting project needs to be completed by Labor Day and my work schedule and local weather forecast doesn’t look to promising. If there is a product available is it easy to utilize or would it be better in the hands of a professional? All help would be appreciated!
Frank Stalfire
08-18-2005 21:36:39
 Re: Any products available to compensate for heat in reply to jdk71, 08-18-2005 10:44:37
What Rod said about the retarders is right on, the only thing I'd like to add is about the humidity, it will only kill your flash time, with the air being so saturated with moisture there is no where for the solvent to go so flash times will increase.
Rod (NH)
08-18-2005 17:10:26
Hi,
As far as I know there is no product that compensates for high humidity. There are usually specialized retarders that can be added to the slowest available reducer in order to slow down the drying even more in very hot weather. I've never found the need to try them since I just don't paint at all when the temperature is over 90F or the humidity is so high, you sweat doing nothing. I am sure BPNT down below will give you different advice, since he apparently likes to paint right inside a 140F bake oven. No wonder he always uses the hottest reducer possible. More power to him.
The pros don't have to deal with such issues since they do their work inside an expensive, climate-controlled booth. If you are a backyard DIY like me, that does all his painting outside, you just cannot have rigid, must be done by, painting schedules. You are too dependent on weather unknowns.
third party image Rod
