Removing rust, when is enough, enough?
hope farmer
08-20-2005 18:42:08
I'm rebuilding an old sickle bar mower which is in pretty good shape mechanically speaking. Its a McCormick A24 but you couldn't tell it because there is little or no IH red on it anywhere. What I've found is mostly rust. As I've been scrubbing away with the wire brush and scrubbing pads, the surface rust comes off easily. The rust underneath looks almost like its painted on. I run the power wire brush over it it gets very shiny and looks almost like gloss paint. I'm sure this would come off with a sand blaster or disk grinder. I'm wondering if I get all the loose stuff off and use a decent paint (maybe with primer, maybe not) would I end up with something decent for 5 years or would the rust come through in a year? It will be stored inside. Its not a show piece but I don't want to have to redo it in the next couple of years either. Thanks for your input. Any suggestions on a good primer to use with the IH 2150?
Jason(MA)
08-22-2005 04:53:16
 Re: Removing rust, when is enough, enough? in reply to hope farmer, 08-20-2005 18:42:08
third party image
Here is what I did with my IHC # 12 mower, built 1934-35. I took the main frame down to a commerical sandblaster. Spent $30, they wanted lunch money. I did not ask for a reciept. I then primed what was sand blasted with PPG's DPLF epoxy primer. I striped down the PTO, pitman and other small parts with a wire wheel mounted to a grinder. I then brushed Napa's rustconverter on with a disposable foam brush. Then sprayed with more DPLF and topcoated with ppg's concept in 70019 (IH50) and 10067 (IHblue, pre 47). A couple quick comments, The primer and paint I used is over kill, PPG's omni would be an excellent choice, I went with DPLF and Concept to get some practice in with it before I paint my allis G. The blue I used is more of a baby blue, I don't know much about the later blue but what I've seen its a much darker color.
Mike S 806/H
08-21-2005 13:52:43
I use caseIH 2150 paint, when I paint the paint I have left in the gun I put it on a old ditcher out back,sometimes sprayed or brushed on, There is no prep work done to it and it is pure rust! It has been on there for 3 or 4 years now and sets out side every day and still looks ok, I would say if you prime it with rustoleum rusty metal primer first then use the 2150 it should hold up,
Rod (NH)
08-21-2005 15:34:19
 Re: Removing rust, when is enough, enough? in reply to Mike S 806/H, 08-21-2005 13:52:43
Hi Mike,
Have you successfully used that exact combination so you are sure it works w/o a problem? I only mention it because Rustoleum specifically recommends against it. Here's the wording from the link:
"Can I use Rusty Metal Primer and Clean Metal Primer on my car?" "Stops Rust Auto Primer is formulated for use with automotive touch up paints. Rusty Metal and Clean Metal Primers should only be used if top coated with Rust-Oleum paint."
third party image Rod
Mike S 806/H
08-22-2005 15:31:05
 Re: Removing rust, when is enough, enough? in reply to Rod (NH), 08-21-2005 15:34:19
I have used Rustoleum rusty metal primer on a set of front wheel castings on my Farmall C, I wire wheeled them first, Then primed I let the primer set for a week or so, then sprayed 2150 over them, no problems its been 3 years now, it is stored inside, only out when there is a tractor pull,
CNKS
08-22-2005 17:10:36
 Re: Removing rust, when is enough, enough? in reply to Mike S 806/H, 08-22-2005 15:31:05
A lot of things will work -- I stay with the same brand of primer and paint all the way through, because I don't want to take the chance of having to do them over. But, CIH 2150, being an old style paint, is probably compatible with most any primer, particularly if the primer is cured. As far as rust on the C wheels, I would rather wire brush them, use Picklex 20 on the remaining rust (brushed on), then use epoxy primer. I am sure of the compatibility of those products, because it is pretty much my standard procedure, except I usually sand blast the items that I can tape off the openings of, those that I am sure I can get the sand out of. (lousy sentence) More than one way to do things -- that's what this forum is for.
CNKS
08-21-2005 16:59:54
I doubt if I ever use a "rust type" paint or primer such as Rustoleum. I much prefer to remove all the rust I can, and then theoretically neutralize any remaining "residue" with a product such as Picklex 20--I realize that Picklex is not a true rust converter, but I am talking about VERY little remaining rust, mostly in the nooks and crannies of cast parts that I did not sandblast for some reason. Since 806 just wants to hide the rust have it look red and not care about the quality of the finish, then what he does may be ok. Could be that 2150 (basically an alkyd enamel) is compatible with the rusty metal primer. My only experience with 2150 is with the spray can version that I have attempted to use over the factory primer on some small aftermarket parts -- it does not work, but is lifted by the primer, usually within a few minutes of application. However, if I had an implement on which I did not have to have a like new finish, and also that did not have to have an exact color match, I might consider what is in the link -- (haven't used it).
Mike S 806/H
08-22-2005 15:58:56
 Re: Removing rust, when is enough, enough? in reply to CNKS, 08-21-2005 16:59:54
Hope Farmer was asking for something to hold up for 5 years or so, Im sure it would hold up for that time/probley more!! We painted a V-ripper complete rust!! wire brushed it then power washed it ,painted with Quality Farm primer and paint about 10+ years ago, it looks as good as the day it was painted! I will agree if I was painting my truck I would used a good auto paint, for somethings I see no reason to spend big $$$ for it. I do care about the quality of my finish on my tractors all sprayed with 2150 with hardener (acrylic) My paint jobs look better then most of the guys that used automotive paints,
Rod (NH)
08-20-2005 20:46:30
Hi,
If you consider the Extend that I mention in my post below to VanO, the tech sheet for the Permatex product is here. The sheet for the Loctite product is here. I believe they are the same product since Permatex is under the Loctite corporate umbrella. The Permatex version is available at NAPA in small quantities - 8 oz I think for about $10. Despite what the tech sheets say, I would not recommend spraying the stuff. It sets up pretty fast. I almost ruined an expensive gun once that way. Since it sets up rather fast, it also is difficult to brush on with a bristle brush without leaving noticeable brush strokes. I have found that carefully using the throw-away foam brushes work well for applying it. The tech sheets also say you don't need another primer, but I use epoxy anyway, since I like it so much :o). I'd scuff the Extend with a Scotch-Brite pad before either priming or topcoating directly.
When I painted my AC-B gas tank I used Extend on the entire bottom area. some of the bottom portion of the tank was pretty tender with rust both inside and outside. It also had a couple of pinholes. I wound up brazing (caution - safety issue here!) the pinholes up but I didn't want to sandblast the tender area because I could have just made things worse. I lightly wire brushed the loose rust off. I then applied the Extend, epoxy-primed, then used a surfacer and finally topcoated. I would not have bothered with the surfacer on an implement. I also lined the tank interior with a heavy epoxy coating (not the same stuff as the primer). That was three years ago and there is no sign that the rust areas that were on the bottom of the tank have returned in any way.
There are other products than the Extend for such a treatment but I have no personal experience with them. I do believe the type of remaining rust that you speak of is not a situation where a phosphoric acid treatment would be called for. I consider that type of treatment as a minor surface rust removal, metal etch type of process. At least as far as the phosphoric acid treatments I have used in the past are concerned. There are many, many quick fixes claimed for rust out there. And a lot of hype, I suspect, to go with the claims. The best method is complete removal of all the rust, either by grinding or sandblasting. However, as in my tank case, that is not always practical and you have to choose a second best alternative. How one really makes an intelligent choice for that alternative amid all the claims is beyond me. I can only advise that the Extend has worked for me so far.
CNKS
08-20-2005 19:32:42
There are two posts below, one by VanO, pay attention to the response by Rod(NH). The other has "Blue lacquer" in the title, read the response by Jason(MA). Even if you use 2150 (wrong shade of red), use epoxy primer under it, as opposed to the CIH primer. Or ask Jason what he used.
