How well will PPG DP-40 hold up without topcoating
JD720
08-22-2005 19:23:37
I am getting ready to start on an unstyled G .I plan on sandblasting all the pieces then spraying that metal prep you get from Lowe`s before I spray it with the DP-40. This is going to be a very long process it will probably take 2 to 3 years before I am ready to finish the job.The pieces will be stored in a pole barn but here in Indiana things seem to sweat really bad in the spring and then we have the humidity in the summer.Is the metal prep and the DP-40 the best way to keep it from rusting back through ? If not then what would you suggest ? Thank`s
Rod (NH)
08-22-2005 20:08:07
 Re: How well will PPG DP-40 hold up without topcoa in reply to JD720, 08-22-2005 19:23:37
Hi,
DP40 is an outstanding epoxy primer. It has been around for many years. I've used it on a Honda Civic cowling, not topcoated, that was outside in NH weather continuously for about 10 years w/o any rust showing up. That was directly to a sandblasted surface. I don't believe there is a better bare metal primer in existence. If you are going to sandblast the parts to a bright metal blast condition, I would not bother with any type of metal prep, as long as you can apply the DP40 the same day. BTW, DP40 is an old designation. The newer one is DP40LF, the LF portion signifying a lead-free product - it's the same grey/green color though and now there are two different catalysts available (for the LF version only). For your purposes I recommend you apply two full coats after blasting. Be aware that epoxy primers have a topcoat window. That means after 7 days for the DP, the surface will have to be scuffed and another coat of the DP applied before topcoating within the 7 day period. It's not a big deal. Other epoxies have different, shorter windows - the 7 days are for the old DP and the newer DPLF only.
third party image Rod
