Rod, Just to make sure were on the same page about HVLP, The systems that Marlin and I are using, use a little "turbin" fan box that puts out a very high volume of warm, dry air. Its much like the output of a vacume cleaner. (blower side) except very high volume air. There is no compressing of the air, so typically you dont have to worry about filters and line driers. I am sure you have seen these rigs before but wether you have used one or not Im not sure, kind of a poor mans spray rig, although they are quite expensive. When these turbine units come into play, all HVLP guns aren't created equal. I was ready to buy a decent gravity feed HVLP gun the other day and the guy said that I have to use low pressure shop air to run it and then get filters and driers and the like. I would still like to do that because I here you get a much better finish with these shop air HVLP guns. I used an Accuspray series 10 bleeder gun and the turbine on the last tractor I painted and the results were good, but not as good as I have seen in my buddies body shop where he uses shop air HVLP, thats why the curiosity. I guess what Im trying to say here is that, you cant use any of the higher end HVLP guns on these turbine systems, they are a different animal all together. That being said, I am still curious if the tip, nozzle, air cap parameters spelled out in your post still apply to these "turbine style" guns? 99% of all the better HVLP guns made by Sata, Devillbis, Sharpe, and whoever else are designed to be used on shop air. Accupsray does make 1 gravity feed gun for the turbine system but I am starting to shy away from it and I am looking at DeVilbiss, Sata, Sharpe, etc. I would like to get a shop air spray system set up with filters, etc. for other work I get into. Any recomendations on guns, filter types, driers, etc? scott#2
