Scott, That mask of mine is about 25 years old. It's a continuous flow, full face, supplied-air mask intended to be supplied with air from a compressor, not a turbine like the Hobby-Air units. It is made by Pulmosan Safety Equipment Co. which seems to be out of business, or absorbed by somebody else. Currently, both SAS and Survivair (and probably others) have similar masks, available both individually and complete with small, tankless, oil-free breathing air compressors to provide the air. I use an old 1hp portable Campbell-Hausfeld compressor (also oil-free and tankless, but noisy) to supply the mask through 50 ft of standard 3/8" ID air hose. It operates at about 3.5-4 cfm at about 8-10 psig while supplying the mask. That's about the minimum supply capacity needed for a mask. A hood requires a little more, something like 6 cfm as I remember. I always verify there is adequate capacity to maintain a positive pressure inside the mask by inhaling, while at the same time checking with my hand for a continued positive outflow of air at the exhaust port. The outflow of air will always decrease during the inhale, but if it actually stops, positive pressure is lost momentarily, which is an indication the air supply rate is inadequate. My system has no formal agency "approvals" except possibly for the mask itself (if so, it's probably not current). It works fine for my purposes. It's not for someone who needs to wear regular glasses while painting. If that's the case, the full hood is probably the better choice.
