Priming over old paint
James Nauert
09-11-2005 03:03:47
Is it ok to prime over old paint that has been sanded. Or should i spot prime.
CNKS
09-11-2005 10:40:28
 Re: Priming over old paint in reply to James Nauert, 09-11-2005 03:03:47
If the paint is sound, you can sand and apply epoxy primer. In addition to priming the epoxy will act as a sealer. Put a sandable surfacer over that, then topcoat. However, on tractors, unless you have a newer factory finish, I do not consider the old finish sound, particularly if it has been repainted. If it was mine I would strip to bare metal.
CNKS
09-11-2005 10:43:19
 Re: Priming over old paint in reply to CNKS, 09-11-2005 10:40:28
I didn't answer your second question -- Again this applies only if the paint is in good shape -- IMO, prime the whole thing and don't mess with spot priming. Others may differ.
Joe(X)
09-27-2005 14:37:43
 Re: Priming over old paint in reply to CNKS, 09-11-2005 10:43:19
I agree with CNKS. Prime it all and seal it. Nothing worse than spraying the top caot and the old paint blistering due to incompatable paints.
