Epoxy primer
James Nauert
09-11-2005 14:16:11
What make do you recomend and can i go over it with JD primer then JD classic green no hardner.
CNKS
09-11-2005 16:46:32
 Re: Epoxy primer in reply to James Nauert, 09-11-2005 14:16:11
About any epoxy primer from a major manufacturer. To be absoultely sure, you should use all products from the same manufacturer. But, what you want to do will probably be ok. I have not used JD paints, so there is no way I can be absolutely positive. I use PPG Omni 170. It is non-sandable. You need a sandable primer or primer sufacer on the sheet metal if you want it perfectly smooth -- if you can sand the JD primer you are probably ok. You do not need any other primer than the epoxy on the cast or any other part that you don't have to have perfectly smooth.
