rattle can paint
Jake Wilken
09-15-2005 18:01:01
Im restoring my cub and cant afford a new compressor to paint the tractor but i want a good looking and durable finish. Can I use the rattle can primer from an IH dealer and get a good looking finish even on my sheet metal if I sand inbetween coats? Also do you need a different paint than rest of tractor for the eninge? Like a high temp. paint? your thoughts would be greatly appreciated... Jake
CNKS
09-16-2005 12:04:56
 Re: rattle can paint in reply to Jake Wilken, 09-15-2005 18:01:01
If you are skillful using rattle cans you will get a decent finish, I'm not skillful. The paint will also likely fade. Use the same paint on the engine, high temp is not needed.
