base/c clear/c can you re-clear ? Rod/CNKS
KM07
09-16-2005 12:18:27
Hi Guy's,
I bought a project painted a few years ago using omni b/c. The paint looks good but it has "dry" looking spots on it, still a semi gloss but not as good as the rest. I think the previous painter really had to cut and polish to get it in it's current state (looks decent) and I'm guessing the clear is thin and afraid to take a buffer to it - Anyway, since the paint itself look goods is it possible to scuff and re clear to get a good even gloss coverage ? Thanks in advance for yur help.
Frank Stalfire
09-17-2005 21:05:51
 Re: base/c clear/c can you re-clear ? Rod/CNKS in reply to KM07, 09-16-2005 12:18:27
Sure, we do it all the time in body shops on blend panels, sand it either wet with 1000 or a gray or gold scotch brite or dry with 800
Frank
CNKS
09-16-2005 18:21:35
What Rod says, I haven't tried it.
Rod (NH)
09-16-2005 17:41:43
Hi,
Later repair/recoating of clear is not specifically addressed in the OMNI (MC161) tech sheet but I see no particular reason why you couldn't do it as you indicate. I have never done that to clear myself, so I'm not absolutely positive about it. You might want to try some small, masked off (or removed) area first that is not particularly important. I'd sand lightly with 400 grit or use a maroon (7447) 3M Scotch-Brite general purpose hand pad to take off what gloss there is and provide some tooth for adhesion of the additional new clear. That works well for recoating catalyzed single stage - not sure about recoating clear.
third party image Rod
tommyw-5088
09-21-2005 06:07:58
 Re: base/c clear/c can you re-clear ? Rod/CNKS in reply to Rod (NH), 09-16-2005 17:41:43
in the body shop we sanded all our blend panels with 1000 wet ,then cleared no problem .
