Terex Color
Terexer
09-22-2005 13:22:05
Does anyone know the color code or color number on the green pait used on Terex equipment??
Thanks /Dennis
Rod (NH)
09-23-2005 16:03:59
 Re: Terex Color in reply to Terexer, 09-22-2005 13:22:05
Hi Dennis,
There are two greens listed in the PPG listing that I have under "GM - Terex Green". They are formula numbers 2690 and 2693. I don't know if Terex is or was at one time, under the GM corporate umbrella. I also don't know what the difference is between the two different greens. It's something you can check into with a local PPG jobber if you wish. If you know the shade of green or have an old part to go by, you might have to buy a minimum amount of each to satisfy yourself unless you can find something more definitive.
third party image Rod
Terexer
09-24-2005 11:19:03
 Re: Terex Color in reply to Rod (NH), 09-23-2005 16:03:59
Thank you, I will have to look closer to them two colours, but now I have something to go on. Again, many thanks. /Dennis
