paint
tylers
10-06-2005 19:27:21
Help! I have a can of martin-senour prairie gold #99l3749 should be gold #2.
It is really orange compared to ppg prairie gold early gold. what can be done to take the orange out. I have a 1948 RTU which is more of a yellow gold not the orange. Have other people had problems with this brand?
Rod (NH)
10-07-2005 16:34:20
 Re: paint in reply to tylers, 10-06-2005 19:27:21
Hi Tylers,
I doubt anything can be done to "take the orange out". You apparently got the wrong shade mixed and will need to resolve the matter by getting a correct formula for the shade you want. PPG lists two different shades of Prairie Gold, so apparently there were two different versions of the same basic name used by MM. You'll have to check with your Martin Senour jobber to find out what the formula for the other version is, if they have it. I don't use Martin Senour paint so I can't comment on their products, but I doubt very much if your problem is a result of an issue with the brand.
third party image Rod
tylers
10-11-2005 20:46:13
 Re: paint in reply to Rod (NH), 10-07-2005 16:34:20
The paint company sent a pint of very bright yellow base pigment to mix in the gallon. It took about half a pint of yellow for the paint to match ppg's color which was almost a perfect match to the original. Either Martin-senour's formula is not the same or it was mixed wrong.
Thanks for the input.
tylers
10-11-2005 20:43:53
The paint company sent a pint of very bright yellow base pigment to mix in the gallon. It took about half a pint of yellow for the paint to match ppg's color which was almost a purfect match to the original. Either Martin-senor's formula is not the same or it was mixed wrong.
