Minimum temperature for Bondo application
Dave in CT
10-07-2005 05:26:21
What's the minimum temperature one can effectively apply Bondo? It's getting cool here in CT and I need to finish up winterizing my truck.
sammy the RED
10-12-2005 16:31:34
 Re: Minimum temperature for Bondo application in reply to Dave in CT, 10-07-2005 05:26:21
Click the link,
CNKS
10-07-2005 06:21:07
Someone else is going to have to tell you that. Personally, I would not apply below 60 degrees, but I have no basis for that statement, below that it's just too cold for me to get interested in bodywork. Even at 60 degrees it will cure slowly -- You may be better off coating everyting with epoxy primer, it is water proof, and if there is any doubt about adhesion it can be sanded off next spring. (This statement is presented without any form of proof)
Dave in CT
10-07-2005 06:41:30
 Re: Minimum temperature for Bondo application in reply to CNKS, 10-07-2005 06:21:07
Thanks CNKS. Either way, it looks like I'm going to need to figure out a way to get some heat on the job. I did apply bondo five years ago in around 50F or a little lower but that was a quick and dirty job to pass inspection and I'm trying to get this one right.
Dave in CT
10-07-2005 06:40:58
