Filler goes on bare metal? Or after MP 170?
scott#2
10-17-2005 15:33:13
Was just wondering when you put the filler on. Body filler and flowable. Do you put it on the bare metal? Or after its primed?
Thank You,
scott#2
Rod (NH)
10-18-2005 12:47:22
 Re: Filler goes on bare metal? Or after MP 170? in reply to scott#2, 10-17-2005 15:33:13
Scott,
You can do it either way. I prefer to minimize the use of filler by metal working as much as possible to get the filler no more than 1/8" thick and prime with epoxy prior to the filler. Most prefer to apply the filler directly to bare metal instead. My work schedule is slow and I like to get bare metal (usually sandblasted) primed right away - usually within the hour. I then mess with what probably will be more than one application of filler later, after an overnight dry but during the three day time window for MP170. After the window, the application area should be roughed up well, preferably with something like 80 grit.
Rod
CNKS
10-17-2005 16:59:09
Room for difference of opinion. I put filler on bare metal, simply because it is easier for me to do it that way. There are several different kinds of flowable, do what the instructions say. I sometimes use it over body filler to fill pinholes. But, I really don't see much difference in flowable or body filler as to the ease of sanding.
CNKS
10-17-2005 16:58:44
