Painting with HVLP Touch Up Gun
John UB
10-20-2005 12:02:53
Hello,
I'm in the process of restoring a tractor and I'm about ready to start priming and painting. I've read many of the discussions regarding painting a tractor with a HVLP Touch Up gun and I'm thinking of purchasing one, but have a couple questions that I was hoping somebody could answer.
Can you spray epoxy primer using this type of gun? Can anybody provide a good online source to purchase this type of gun? I'm a beginner at all this, so I'm trying to keep the equipment costs down, until I get some experience under my belt.
Thanks for any help you can provide.
John
Rod (NH)
10-20-2005 19:53:07
 Re: Painting with HVLP Touch Up Gun in reply to John UB, 10-20-2005 12:02:53
Hi John,
Sure, you can use epoxy primer in a touchup gun. I do it all the time. Here's mine doing just that with PPG OMNI MP170:
third party image
My spot gun has one standard tip size and really is designed for topcoats but will work fine for epoxy and will even work with surfacer, although the tip is a little small for that - but it still works. If you are doing most tractor parts separately, a touchup (sometimes called a spot or a jam gun) is really quite satisfactory. In fact, if you are short on compressor capacity, a spot gun takes no more than a third to a half the quantity of air required for a full sized gun. They necessarily have a smaller fan pattern and will require more individual passes for things like fenders and hoods, but they will get the job done. I wouldn't want to tackle an entire main chassis at once with one, but if it is broken up into sections that are masked off, and done separately, a spot gun can do the job there also. I like to keep the size of the individual session to what can be covered by one coat with the capacity in the cup. That's not really necessary but I don't like to interrupt completing a coat in order to refill the gun.
Mine's a DeVilbiss but I would recommend, as a beginner, you get something that is less expensive at first. Most of the name brand spot guns (DeVilbiss, Sharp, Sata, Binks, for example) are going to be in the $200 plus category, perhaps closer to $300. I'd start out with something like a Campbell-Hausfeld for $50 or less. I've seen them at Home Depot and usually the chain auto parts stores have them also. I suspect you can find an on-line source for something like that but I don't have a link.
I wouldn't get hung up on HVLP. You don't really need it unless there is some local air emisson law that absolutely requires it. Gravity feed is most popular nowadays (usually HVLP) and is easier to clean but suction feed is an old standby and works well. If you start out relatively inexpensive, it's easy enough to upgrade later, if desired, as you get the hang of things.
third party image Rod
CNKS
10-20-2005 16:50:14
Epoxy primer generally uses the same tip size as does the topcoat. Surfacers usually require a larger tip, but since you have to sand surfacer anyway it may not matter -- I can't remember if I have used surfacer in my touchup gun, I don't think so. I would rather use a full size gun on large surfaces, but it is surprising how much you can paint with a touchup gun. Do a search for paint guns, you will get all sorts of results.
John UB
10-21-2005 07:49:38
 Re: Painting with HVLP Touch Up Gun in reply to CNKS, 10-20-2005 16:50:14
Thanks guys. You guys are a tremendous wealth of knowledge.
Regards,
John
