1961 JD 4010 Paint Color Code
61-4010
10-21-2005 10:55:44
Hey friends. 2 questions for you gurus. First, want to confirm that a 1961 JD 4010 uses Classic Green as defined by JD. Secondly, in working with our local PPG paint company, they need a paint code so they can mix it accordingly. Going with PPG Concept as I want this to last and be ultra durable. So would appreciate this info!
CNKS
10-21-2005 19:54:05
 Re: 1961 JD 4010 Paint Color Code in reply to 61-4010, 10-21-2005 10:55:44
The link is to Rod(NH)'s listing of PPG's paint codes -- for some reason I can't get it to work at the moment -- if it works for you, or even if it doesn't you still need to confirm the name of the paint JD used in 1961 with someone on the JD board -- I imagine it is mentioned many times in the archives.
Rod (NH)
10-22-2005 13:20:49
 Re: 1961 JD 4010 Paint Color Code in reply to CNKS, 10-21-2005 19:54:05
CN,
You had an incorrect address for the link. That's why it didn't work. You had this:
Link
CNKS
10-22-2005 18:41:49
 Re: 1961 JD 4010 Paint Color Code in reply to Rod (NH), 10-22-2005 13:20:49
I had your link bookmarked, it always worked before, but now I have it as an new link with the correct (new??) address.
Rod (NH)
10-22-2005 19:13:05
 Re: 1961 JD 4010 Paint Color Code in reply to CNKS, 10-22-2005 18:41:49
Well, you're correct. After some research, I notice that I changed the file name and moved the address location when I updated my original PPG list last March with a lot of newer PPG info that Jason(MA) provided for me. The link you had was for the older list that I removed. Sorry about that. I should have kept the same file name and location for the updated list just so the previous link would work.
CNKS
10-22-2005 19:33:03
 Re: 1961 JD 4010 Paint Color Code in reply to Rod (NH), 10-22-2005 19:13:05
You should know -- but I think I used the old address in the last month and I'm positive I used it several times since March, perhaps it's magic or something. I always make sure it works after I post it for other people, I've done that several times since you updated it, yesterday is the first time it didn't work.
