CNKS
10-21-2005 19:46:40
Re: Best way to paint a tractor in reply to Christos, 10-21-2005 18:44:23
61-4010 pretty much said it. I prefer to strip everything to bare metal, that is very time consuming. If the old paint is in good shape, the epoxy will seal it, one problem you may have is that there is likely rust underneath it, which sooner or later will come through -- your choice. If you can't afford PPG/Dupont, etc, then at least use the paint from your MF dealer, it will likely be better than the tractor store stuff. As to what to remove, the distributer, carburetor, air cleaner, oil filter come to mind, along with anything else you can easily remove--I am not familiar with your tractor. The gun is supposed to be held 90 degrees from the surface, you will not be able to paint the back side of anything without removing it, along with not getting coverage of the area behind such parts. You won't be able to properly remove the old paint and crud, either. I don't care for cheap paint guns, if you plan on doing more than one tractor, at least buy an intermediate priced one. But, the inexpensive ones may be ok for occasional use. Since you don't want to spend much money, stay away from hardeners, as they require a supplied air system to protect your health -- will cost $4-500+.
