P.S.
Rob N VA
10-27-2005 18:59:52
TSC also sells hardner for theis tractor paint. What is it, and do i need it? Thanks again!--Rob
CNKS
10-27-2005 19:45:29
 Re: P.S. in reply to Rob N VA, 10-27-2005 18:59:52
Do NOT use hardener in any paint unless you have a supplied air system (about $500). The isocyanates in hardener can cause severe respiratory problems. A charcoal mask is not adequate, don't let anyone tell you that it is. Read the replies by Rod(NH) in the "Applying Decals" post below. Acrylic enamel does not require hardener, nor does the "acrylic modified" alkyd enamel that Rod mentions.
