What do you guys think of these compressors?
scott#2
10-28-2005 16:11:42
I was looking real hard at the 7.5 hp unit. Any comments, etc? Good for sand blasting?
scott#2
jdench
11-03-2005 16:45:55
 Re: What do you guys think of these compressors? in reply to scott#2, 10-28-2005 16:11:42
Hmm....
Looked all over the site and couldn't find where they are made or what the amps are.
Lot of references to "we make" and "factory", and a couple of pictures of red white and blue compressors, so my bet is China. Hey, the quality of Chinese machinery is getting better by the day so that's not a problem, but I like vendors to be straight with me.
Re amps, since everyone cheats on HP ratings, the only valid measure of power is amperage. So I get suspicious anytime someone lists a HP rating and no amps.
evielboweviel
11-24-2005 14:19:53
 Re: What do you guys think of these compressors? in reply to jdench, 11-03-2005 16:45:55
2cd row far right in description
1750 rpm 32 amps
Ron
scott#2
11-04-2005 18:47:43
Actually, their made right in Ohio by a family owned business. Click on a compressor model and read the specs. After addl. research I am looking at the 10 hp 120 gallon model, but with the 3 cylinder pump, not the v4. Do a search on ebay, Eatom compressor and theres more info there as well. Actually a great buy for a loaded quality compressor.
scott#2
SWI Don
11-05-2005 17:05:01
 Re: What do you guys think of these compressors? in reply to scott#2, 11-04-2005 18:47:43
Scott,
I have the equivalent to the 7.5 hp V4 120 gal compressor. It was put together by my uncle who used to sell a ton of them. The pumps for the V4 compressors and the 2cyl ones that look related are made in China. Saylor Beal tried to set up in china a long time ago ~80's. It didn't pan out - the Chinese couldn't do the castings very well at the time. They have since improved over the last 20 odd years and are a good unit. There are a few outfits arount the US that assemble compressors using these pumps. I believe mine would be realated to the Industrial Air / Industrial Gold brands that were/are made in Kansas / Missouri.
I have seen in several forums that the guys that have bought the Eaton compressors have been very happy with them.
Don
MPND
11-03-2005 20:53:53
The globe in the upper right shows what looks to be SE Asia so...
CNKS
10-28-2005 17:17:19
The 26 cfm is similar to mine -- adequate, but not outstanding, it depends on how fast you want to get done. A scan of the specs does not indicate that it has a 100% duty cycle, mine doesn't either, wish it did. The manufacturer told me I could run it about 15 minutes at a time, when refilling my sandblaster, that's about how long it gets run. With a Quincy (more $$ for the same CFM) you won't go wrong. The compressor is probably ok, but I don't consider it a heavy duty, run for long periods of time type compressor, mine isn't either, but I'm satisfied with it.
