What ratio to mix JD Brand paint?
Nicolas
10-31-2005 18:50:51
I am going to use John Deere brand enamel to paint my tractor. About what ratio should I cut it? I will be using a regular suction feed spray gun. Also, about what air pressure should I set the regulator at? Thanks, Jdman
Nicolas
11-01-2005 04:21:12
 P.S. in reply to Nicolas, 10-31-2005 18:50:51
I see alot of good comments on here about epoxy primer, what should I use to thin it and how much? Thanks, Jdman
CNKS
11-01-2005 07:02:18
 Re: P.S. in reply to Nicolas, 11-01-2005 04:21:12
Basic rule -- If the paint does not come with instructions, don't buy it. If it does not say on the can, then ask the supplier for the instruction sheet, or go to the manufacturers web site. Epoxy primer is not usually thinned, and is two part, that is you add hardener according to the instructions. I know nothing about JD paint -- do what it says in the instructions.
Billy C.
11-01-2005 09:34:03
 Re: P.S. in reply to CNKS, 11-01-2005 07:02:18
The JD Classic Green that I bought but haven't used yet says mix one part thinner to 10 parts paint. I also bougt JD thinner.
