painting vs humidity
frito
11-07-2005 09:33:23
Hey guys, I'm restoring an A/C G When I started priming and painting the humidity was in the low 40's. Before I could finish the humidity is now in the 70's range. What would be an acceptable humidity range to paint. I'm painting under an open shed. Thanks for any info.
Frank Stalfire
11-10-2005 18:31:22
 Re: painting vs humidity in reply to frito, 11-07-2005 09:33:23
It depends on the type of paint you are using, anything with an Isocyanate will cross link faster in high humidity but flash slower, thus dye back and lose gloss. an alkyd and laquer will hold moisture and tend to blush in high humidity. enamels are pretty stable except for a slow flash
Frank
