Winter painting....bad idea?
UCPetty
11-16-2005 08:46:58
What kind of results should I expect if I was to paint in my shop during the winter (early December in Ohio)? Let say I can maintain an air temp of 50 degrees using a space heater or maybe warmer by directing the heat towards the surface to be painted. I will be using International implement paint (rattle can). I know this may be a poor idea, I just want some more detailed reasoning to discourage the idea if necessary.
CNKS
11-16-2005 17:19:27
 Re: Winter painting....bad idea? in reply to UCPetty, 11-16-2005 08:46:58
Dry times, flash times (the period between coats) will be greatly increased, along with the potential of a less than satisfactory job.
tommyw-5088
11-17-2005 16:14:23
 Re: Winter painting....bad idea? in reply to CNKS, 11-16-2005 17:19:27
isocyanates dont crosslink below 60 degrees ,if you arent using hardner just wait longer .
