Repaint Acrylic Enamel over Acrylic Urethane?
Barry Maxwell
11-19-2005 04:27:17
Many months ago I painted tractor parts with PPG acrylic urethane gray paint with hardener. It turns out that 3 of the parts should be red. I am ready to repaint these parts with CIH 2150 acrylic enamel with hardener that is used elsewhere on the tractor. Will this be acceptable, or will I have problems? Thank you for any responses.
Rod (NH)
11-19-2005 05:23:37
 Re: Repaint Acrylic Enamel over Acrylic Urethane? in reply to Barry Maxwell, 11-19-2005 04:27:17
Hi Barry,
You should not have any trouble at all putting AE over AU. Just make sure you scuff up the AU with either 400 grit or a maroon (general purpose) Scotch-Brite hand pad.
third party image Rod
Barry Maxwell
11-20-2005 04:28:59
 Re: Repaint Acrylic Enamel over Acrylic Urethane? in reply to Rod (NH), 11-19-2005 05:23:37
Rod:
Many thanks for your response. I will take your advice.
Ed bowen
11-24-2005 17:58:46
 Re: Repaint Acrylic Enamel over Acrylic Urethane? in reply to Barry Maxwell, 11-20-2005 04:28:59
as I was told by a ppg rep it's all acrylic enamel it becomes a urethane when the hardner is used
Ed
