Prayers needed.
Chad (IA)
11-19-2005 16:15:39
We are restoring the 1655D and are having a little bit of trouble with the little instrument panel taking black paint. Have sealed and shot with auto paint...curled. Sanded and painted again.. curled. Concluded that someone must have used rustoleum on it so we totally stripped to bare metal sealed and painted with auto AU paint..spider cracks. 4 coats later later..still spider cracks. So close, and yet this little piece is giving us such a headache. The rest of the tractor is taking everything beautifully. Any ideas???
As soon as the new digital camera comes in I will post some pictures.
CNKS
11-19-2005 17:13:26
 Re: Prayers needed. in reply to Chad (IA), 11-19-2005 16:15:39
Sealed with what? Remove ALL the old paint, sand with 180 grit, treat with wax and grease remover until the rags are clean, apply epoxy primer and topcoat. You don't need to seal bare metal. The sealer and AU you are using now are likely incompatible. If you want an absolutely smooth surface, use a sandable surfacer/primer surfacer over the epoxy. Be sure all products are the same brand to assure compatibility, and make sure the surface is absolutely clean.
Chad (IA)
11-20-2005 06:16:24
 Re: Prayers needed. in reply to CNKS, 11-19-2005 17:13:26
Thanks, I will pass it on.
