Rust-Pitted Metal
CalJim
11-21-2005 21:50:48
The hood for my 44 BW is pitted badly. What is
the cure? I think Bondo would be overkill,what
about spot putty?,can it be spread on over large surfaces? Is there a filler primer that
would work? Thanks
CNKS
11-22-2005 05:06:31
 Re: Rust-Pitted Metal in reply to CalJim, 11-21-2005 21:50:48
Evercoat Eurosoft Glazing Putty is another. Only advantage I see over regular body filler is less pinholes. Sanding may be slightly easier, but not much. Body filler will work also, the pinholes are not a problem if you only leave it in the pits.
Jim WNY
11-21-2005 22:38:01
I think what you're looking for is generally called Icing. A 2-part Polyester filler that can be used as a skim coat over large areas to fill pits, chips, scratchs and pinholes.
I used it along with regular filler on my 8N hood and fenders, followed with epoxy primer and then a sandable surfacer.
A number of brands to choose from. The one I used is called Thin Ice from US Chemical & Plastics.
Personally, I wouldn't use the lacquer based spot putty.
Just my $.02
