First Paint Job
Pete/ME
12-12-2005 03:27:52
My first time painting...a '49 B. Just want a half-way decent job, I expect to work the tractor. It's pretty much all apart, I wirewheeled and disksanded the loose paint and rust off, but there's still rust here and there, getting down to bare metal on all the parts seems to be overkill for what I want. Can I just rattlecan primer over the sound paint and light rust--the grey stuff or Rustoleum red? The finish will be JD classic, I bought a HVLP gun, but will have to wait 'til it warms up, I kinda think it wouldn't be a great idea to spray with my wood stove going.
soundguy
12-14-2005 12:25:52
 Re: First Paint Job in reply to Pete/ME, 12-12-2005 03:27:52
Still being an amature painter myself.. I've got to say that the finish paint job is 70% 'prep', and only 20% environmental, and only 10% materials and tools.
That said.. I use a 9$ chinese paint gun from harbor freight, and up until this year used a 19$ air regulator/ filter also chinese, and an 89$ pancake compressor.. also chinese.
For paint and primer, i use the BPS paints and primers.. ( not the most expensve stuff.. but not the absolute cheapest either.. ).
Given the cheapy tools.. and economy paints, I must say.. i've turned out some paint jobs that look pretty darn good. in the last 3 years, I did my 46 ford 2n, 49 Allis chalmers G, and a 75 ford 5000. All turned out with a finish like glass... I have a couple pics o fthe allis G where you can see reflections in the paint it is so shiny. Even the cast turns to a glass finish.
It wasn't the 24$ / gallon paint.. or the 9$ gun. It was the 2 weeks of sanding and work on the tin, and just a little bit of 'weather' planning looking for a low humidity, no/lo wind / NO rain day that was partly cloudy..with temps between 40' and 90', as you don't want bright hot sun.
Like I said.. i'm way amature.. but..I've gotten superior results thru practice.. not practice at painting.. practice at sanding and beating and filling dents... etc.
Also.. add a touch of class to a job.. Do as good a masking job as you do finish prep.. that means.. tape off hoses, belts, and wires.. Nothing says 'auction paint job' more than painted hoses and belts and wires...
good luck and have fun!
Soundguy
Mike S 806/H
12-14-2005 08:55:34
Use oven cleaner spray it down good and let it set when it looks like it starting to dry spray it again let it set you should see the old paint running off and then pressure wash it with hot water, I do this on a nice day to get it to dry quick, then its ready to prime, I would use the JD buff yellow primer, I wouldnt use the rattle can's, as for the HVLP gun hope you have a good air compresser! I dont like HVLP guns
Seth_ia
12-14-2005 17:44:37
 Re: First Paint Job in reply to Mike S 806/H, 12-14-2005 08:55:34
I totally agree about HVLP guns. Rattle can primer is fine for small parts, that you want to keep from rerusting after you have cleaned them up. But use Deere primer on every thing else that is going to be painted with Deere psint. Also be sure to use their thinner. Never mix and match paint products. Good prep is maybe 50% and using good technique is the other 50%. That assumes that you are using a good gun and materials to start with. Good technique must be learned throuh repeated practice.
rustyj14
12-14-2005 08:34:00
Well, if ya want to take a flight, without the benefit of using an airplane, why, go ahead and spray paint with that wood stove burning! And, yes, you should wait for warm weather! Paint doesn't dry well in the cold! And, if ya aren't too worried about how it'll look when yer done, paint it with those sponge brushes, available at the discount or hardware stores! I've painted carts, tractors, etc. with them, and they looked o.k. when done. I even painted my old pickup with them, and it looks o.k. It was a rat to start with, so no loss! And, i've brush painted with my kero stove working, and didn't have any trouble, but NOT SPRAY PAINTING! If you do it--just wave as ya pass over the house! Rustyj
