tire cutting
bm3501466
04-20-2008 16:41:17
I have a set of tires I want to cut myself. How do I do it? What tools do I need?
RWOLFEJR
04-22-2008 07:06:57
 Re: tire cutting in reply to bm3501466, 04-20-2008 16:41:17
Link
This is the type of wheel you need. Rubberhog also makes these.
Bob
jd b puller
04-21-2008 12:22:33
 Re: tire cutting in reply to JThomas, 04-20-2008 16:41:17
1. Bottle Jack
2. 4-5" grinder with special wheels
3. Power Planer
4. Respirator/dust mask
5. Stone to sharpen the planer blade
6. A lot of patience
block up one side of the tractor. Use the planer to lay back the tops. Then come back in with the grinder and to the fronts/finish the tops.
Set the planer to a fairly thick setting. When the shavings from the planer start to get real small and "dirty/dusty", the blade is dull.
About 4-8 hours per tire
