Bad Molines
Ron
05-11-2001 06:56:12
I've heard that there is a M5 and a GIV Moline down in the Carolinas and they are awesome. Does anyone know anything about them?
G Taylor untimate mix match stock class stroker/overbore
05-12-2001 08:53:49
 Re: Bad Molines in reply to Ron, 05-11-2001 06:56:12
Minnie Moline, the untimate machine for the stock appearing class with an oversize engine.
Dave N
05-11-2001 19:30:36
Yes I built them what do you want to know Dave
Glenn
05-12-2001 04:12:53
 Re: Re: Bad Molines in reply to Dave N, 05-11-2001 19:30:36
I'd like to talk to you about them sometime. I pull MM's . Run a GBD now that does well. Glenn
joe
05-11-2001 19:39:04
WOW-you built them!! What a stud!! Let's all bow to him!! O.K., now go back to your little world and enjoy!
D Neubert
05-12-2001 04:46:48
 Re: Re: Re: Bad Molines in reply to joe, 05-11-2001 19:39:04
Joe a question was asked I answered it. bowing down to me is not nessecary. But thanks for the offer. Dave
Allen P.
05-12-2001 07:13:10
 Re: Re: Re: Re: Bad Molines in reply to D Neubert, 05-12-2001 04:46:48
Nice response Dave.Are you pulling the Cocshutt 570 this year or did you manage to get another tractor put together?
Take care,
Allen P.
D Neubert
05-12-2001 07:38:36
 Re: Re: Re: Re: Re: Bad Molines in reply to Allen P., 05-12-2001 07:13:10
Allen I sold the 570 this spring. Got Colleens E-5 put together and it is doing good for what it is. Iam starting on a G-1000 for our local Super Farm classes. it will have a 585 turboed but wont be ready till next year. Have you been pulling yet? Dave
Allen P
05-13-2001 03:19:08
 Re: Re: Re: Re: Re: Re: Bad Molines in reply to D Neubert, 05-12-2001 07:38:36
Hopefully I will pull next Sunday. I have a few details to finish up on the tractor and I am way behind on other chores at home. It will be a work in progress and certainly will not be pretty this summer.
Next year I hope to put a Super 99 GM together if I can figure out how to get enough hooks for it. I keep lobbying one local group to allow GM powered tractors. Right now they have a rule where it must be naturally asperated but it needs the supercharger to run. I may change my mind and build a LP G-VI or a Massey 95/97 as they should be about the ultimate the way the rules are set up. Then again I may junp to their hot farm class which uses limited rpm's, cubes, small turbo and no water injection with the 99.
The Moline should certainly be different from what they normally see. Given your touch I'm sure it will run with the best of them.
Take care,
Allen P.
G Taylor what kind of rules are those?
05-15-2001 22:17:24
 Re: Re: Re: Re: Re: Re: Re: Bad Molines in reply to Allen P, 05-13-2001 03:19:08
What kind of officials would declare a stock engine illegal when it was factory equiped with the blower?
Allen P.
05-18-2001 05:13:35
 Re: Re: Re: Re: Re: Re: Re: Re: Bad Molines in reply to G Taylor what kind of rules are those?, 05-15-2001 22:17:24
Short sighted, arrogant, egotistical, ignorant, etc. are some of the words that have come to mind in my dealings with them. Lazy too, as they didn't seem to be willing to do any research after I started to ask the question.
Gary
05-16-2001 03:43:57
Probably the same idiots who won't let a tractor
pull with the tire size it came from the factory
with and then call it a stock pull.
troy
05-12-2001 08:14:19
What do you have in the E-5? D-19 crank, cam, what else? I am looking for ideas myself.
