Dead Weight pull Fowlerville, MI 5-10
Earl Griffes
05-07-2008 18:17:25
The County Line Antique Tractor Club will be holding their first dead weight tractor pull at the Fowlerville Fair grounds. It will be pulled on a dirt track. weigh in before your class, pull to start at 10 am with the 2500 pound class. COUNTY LINE
ANTIQUE TRACTOR CLUB
Dead Weight Dirt
Tractor Pull Rules
General Rules:
1. Contestants enter at their own risk, County Line Antique Tractor Club and the Fowlerville Fair Grounds will not be held responsible for any injuries, accidents or property damage.
2. Any puller under the age of 18 must have parent or guardian sign them in at the time of pull sign up. All pullers must be able to operate their tractor on their own.
3. Weight classes: 2,500, 3,750, 4,750, 5,750, 6750. Weight to be added to pulling sled each round of 500 pounds in the 2,500 and 3,750 classes and 1,000 pounds in each round in the 4,750; 5,750 and 6,750 classes. Boat to be pulled a distance of 12’ to be considered a full pull. Measurement to be taken if less than a full pull to determine placing in class. There will be no boat spotting during each class.
4. All pulls to be from a tight chain. Drivers must stop as soon as the flag person signals to stop. Driver will have 2 attempts at each load if needed.
5. Driver will have option of direction of pull on second attempt when room on pulling track allows. If rear tire of tractor touches the out of bounds line it will result in a disqualified pull attempt.
6. Excessive engine RPM is not allowed.
7. Drivers must remain seated on tractor while making pull. One hand must be on steering wheel at all times while pulling.
8. Hitch height is to be no more than 18” high and actual hitch point (hitch hole) must be behind the radius of the rear tires to be checked with a string at the hitch height. Hitch must have a minimum 3” opening, must be rigid in all directions, no loose clevises.
9. Front end rise shall not be excessive or unsafe on or off the track. Wheelie bars are recommended.
10. Judges reserve the right to stop any contestant considered operating in an unsafe or dangerous manner. Judges reserve discretion on all rules stated and not stated.
11. All weights must be securely fastened, if any weights or tractor parts fall off tractor during the pull attempt the tractor will be disqualified. Weights must not extend behind the radius of the rear tires, and must not extend further forward than 11’ from the center of the rear axle.
12. Tires spun backwards are allowed, Top cut tires are allowed. Full cut tires are NOT allowed. No dual tires allowed. No four wheel drive tractors allowed.
Maximum Tire size for each class:
2500 class 145 sq in
3750 class 170 sq in
4750 class 210 sq in
5750 class 252 sq in
6750 class NO Limit.
13. No adding of weight after weigh in for each class including gas. Judges reserve right to weigh any tractor at any time.
14. More than one puller may pull a tractor in any class, each tractor may only receive one placing in each class. Tractors are allowed to pull in more than one class.
Earl Griffes
05-09-2008 16:04:15
 Re: Dead Weight pull Fowlerville, MI 5-10 in reply to DANNY HOGGE, 05-07-2008 18:17:25
Here are some max tire sizes for each class
2500 13.6 x 24; 13.6 x 26; 13.6 x 28
3750 14.9 x 24; 14.9 x 29; 14.9 x 28; 13.6 x 38
4750 16.9 x 28; 14.9 x 38; 15.5 x 38
5750 16.9 x 30; 16.9 x 34; 16.9 x 38
Hope this helps.
The reason for the hitch point is required behind the radius of the tires at the hitch height is because we are not requiring wheelie bars at this time.
james rumph
05-09-2008 19:37:02
 Re: Dead Weight pull Fowlerville, MI 5-10 in reply to Earl Griffes, 05-09-2008 16:04:15
Great!!!
Thanks for clearing things up . We all have wheelie bars and are hitches don't fit your rules.
Our hithes are based off the center line of the axel [ 18 or 20" out].
We have never tried a dead weight pull and would like to , how do our hitches effect us in making the trip ?
Were members of the EMTPA club just north of Detolit, sorry Detroit ..
Earl Griffes
05-08-2008 19:49:02
 Re: Dead Weight pull Fowlerville, MI 5-10 in reply to 1958johndeere620, 05-07-2008 18:17:25
copy and paste the link
Earl Griffes
05-08-2008 19:47:12
 Re: Dead Weight pull Fowlerville, MI 5-10 in reply to Nick Van Sciver, 05-07-2008 18:17:25
We use the flat plate area of this chart, we had a lot of discussion to be more fair to the tractors with shorter tires and the NATPA also uses this type of sq. in. rule for tire sizes.
http://www.firestoneag.com/tirelist_pop.asp?ref=22&load=0
Hug your Wheatland
05-09-2008 01:43:51
 Re: Dead Weight pull Fowlerville, MI 5-10 in reply to Earl Griffes, 05-08-2008 19:47:12
Looks like the break over points are just shy of helping the standard or wheatland tread tractors. The 252 sq.in. limit in the 5750 class allows 16.9x38 tires but does not allow 18.4x30 tires at 258 sq.in. I think the actual advantage goes to the taller tire/rowcrop tractor. I might stop by and watch for a while to get a pulling fix.
james rumph
05-08-2008 18:11:13
 Re: Dead Weight pull Fowlerville, MI 5-10 in reply to Earl Griffes, 05-07-2008 18:17:25
How about max tire size not in sq inches , no one list them like this !!!
6000 max 16.8 - 38 example..
And what on earth is the hitch part that goes off the radius of the tire.
It should be measured off the center line of the axle.
My Super M with a factory hitch doesn't come out near the radius of the tires.
Lets put these rules in english so that more might understand them. There is several of us that wouldn't mind trying this but none of us understand these rules.
We would like to come but these rules are strange , make them clearer and you will pull a bigger crowd . Fresh pullers keep it fun .
Earl Griffes
05-08-2008 16:22:39
 Re: Dead Weight pull Fowlerville, MI 5-10 in reply to Dave Thompson, 05-07-2008 18:17:25
Jerry Cent Mi. said: (quoted from post at 12:55:40 05/08/08) The County Line Club is located in Caledonia Mi. and no pull is scheduled and all their pulls are with a weight transfer machine. I believe you are referring to the Clintonia Club.
The County Line Antique Tractor Club is a new club this year and we will be holding a pull on saturday may 10th at the Fowlerville Fair Grounds, it is a dead weight pull, the rules are in the first post.
CLATC
05-08-2008 05:24:26
The information on the Fowlerville pull is correct as is County Line Antique Tractor Club. The name is registered with the State of Michigan.
Jerry Cent Mi.
05-08-2008 04:55:40
