Pierce Governors
460 Man
05-08-2008 07:12:26
Purchased a Pierce Governor for 301 IHC engine, having trouble getting it to work on the motor. So far only able to get it to run at 2400 RPM won't idle. Getting zero help from the person I bought from on Ebay. Can anyone give me some pointers on how to make it work. Thanks in advance.
WallsMSPuller
05-10-2008 18:58:50
 Re: Pierce Governors in reply to 460 Man, 05-08-2008 07:12:26
Add a spring on the arm going to the throtle rod to put tension on it and they work great. Have seen several of them like that.
Kevin Bonwell
05-11-2008 04:02:25
 Re: Pierce Governors in reply to WallsMSPuller, 05-10-2008 18:58:50
How heavy of a spring and how do I attach it?
Thanks
MnM44
05-08-2008 10:01:25
All you have to do is put a demand arm on it and it will work just like a tractor gov. the guys with 800s do this all the time when they put them in tractors.
460 man
05-08-2008 12:18:16
 Re: Pierce Governors in reply to MnM44, 05-08-2008 10:01:25
Please tell me how to do that. I have no idea.
Thanks
MnM44
05-08-2008 16:59:18
 Re: Pierce Governors in reply to 460 man, 05-08-2008 12:18:16
The spring that puts tension on the arm going to the carb is hooked to an arm that is adjusted by a set screw. I just weld an extension on above the pivot point of the arm that is adjusted by the screw. Then i cut off the boss that holds the set screw so it doesnt interfere with the travel. This becomes the demand arm that hooks to your throttle. Then weld the arm solid that goes out to the carb.
IH MM JD
05-08-2008 08:28:21
If that was a yellow Governor, you got screwed. It is a constant speed governor from a MM power unit. Worth about $50.
FixaLinc
05-08-2008 13:56:31
 Re: Pierce Governors in reply to IH MM JD, 05-08-2008 08:28:21
Any idea what numbers or where a chart is to match governors with applications? I have two with v belt pulleys need to get rid of.
460 Man
05-08-2008 09:23:59
Yep, it is yellow looks like I got screwed. I will make sure everyone on E-bay know that the seller can't be trusted.
Thanks.
IH MM JD
05-08-2008 09:35:56
 Re: Pierce Governors in reply to 460 Man, 05-08-2008 09:23:59
I did email him 3 different times and told him that it was NOT an IH governor. I told him it was a MM power unit gov.
460 Man
05-08-2008 09:59:17
 Re: Pierce Governors in reply to IH MM JD, 05-08-2008 09:35:56
Thanks,
I didn't know any better, dumb me. A real person would offer to give a man his money back you would think.
