Re: Econo Mod V8 puller
BOWTIE
05-09-2008 09:33:19
SMALL BLOCK CHEVY
MN Dave 2
05-10-2008 16:06:02
 Re: Econo Mod V8 puller in reply to BOWTIE, 05-09-2008 09:33:19
Extremely nice looking tractor. hope it pulls as good as it looks. What weight classes will you pull? What speed? What did you use for a clutch?
I have a 440 chrysler that I put in a M, but not nearly as nice looking as yours looks. I'm in so. MN, it would be fun to see yours pull, maybe pull against you. (I don't mind getting beat by a good tractor)
BOWTIE
05-10-2008 16:15:21
 Re: Econo Mod V8 puller in reply to MN Dave 2, 05-10-2008 16:06:02
MN DAVE 2
THIS HAS A BUILT TURBO 400 AUTOMATIC MANUAL REVERSE 3 SPEED. PULLS IN 5200# AND 5500# IT WEIGHS 4800# WITH ME IN THE SEAT. THE GEAR COMBINATION SHOULD RUN OUT MID 20 TO 27 MPH GROUND SPEED WITH HIGH WHEEL SPEED. THANKS FOR YOUR INTEREST. WHAT CLUB DO YOU PULL WITH?
MN Dave 2
05-10-2008 21:04:20
 Re: Econo Mod V8 puller in reply to BOWTIE, 05-10-2008 16:15:21
There aren't any "clubs" around here, we just pull with several independent fairs, ....days, that type of thing with each having their own rules which makes it kind of interesting.
What kind of hp are you estimating? What rpm's do you engage clutch? The 20-27mph, was that wheel speed or sled ground speed?
I'm using the same M transmission, have a Ford diesel ton pickup clutch which was same diameter of origional flywheel. My engine is pretty much stock, bigger carb, cam, electronic ign, about 400 hp. Mine too weighs under 5000#, I've pulled as high as 7000#, mostly 5500, 6500#. Sled has clocked me at 16mph which is about as thrilling as I want to get.
It made more sense to me to spend a fraction of the cost of a hot "stock appearing" engine on my whole tractor. It sure is fun to pull.
I've only pulled against a couple of other "hybreds" before. I'm running into a lot of the old "if you can't beat them, only let them pull for exhibition".
