Under load no power
730/1030
06-30-2002 17:32:16
do some pulling and 730 gas running 3000 rpm's is whooping the 1030 deisel running same rpm's any idea's tires/timing/????
buckmaster 700
07-03-2002 21:20:18
 Re: under load no power in reply to 730/1030, 06-30-2002 17:32:16
i think you are talking about a 730 case
it sounds like to me your 1030 in this case has a compression problem and mabe some bad injectors if its a diesel i dont think i would run your 730 up so high it wont last long most pulls around here they only alow 10% over on the rpm
Andy
07-02-2002 08:56:52
How many times has he run the 730, at 3000 rpm's I don't think it will stay together. That's way to much for a JD 2 banger.
